Hi from the Netherlands (Utrecht area)
Come in and say hi. Let us know a little about you and where you heard about the Commander X16 or this forum.
Jeroen
Post by Jeroen »
Hi all,
I just created a forum account and would like to make a quick introduction.
I've been dabbling in electronics and 8-bit computers over the last few years, especially during the lockdown.
Assembled an FPGA-based C64 last year, based on a Gideon's Logic Ultimate 64, a new case and a great breadbin keyboard from a failed original c64. I designed a small PCB for its user port, to light up 8 leds or an LCD screen, selectable by jumper, and programmed it in assembly.  If anyone wants the gerbers to print their own PCBs, let me know.
I then found Ben Eaters videos last year and started a couple of 6502 PCBs and software projects, where the largest project has a ROM bootlader enabling dynamic loading of programs over the serial port by xmodem protocol. Pure magic, to create something like this from scratch.
Then when I thought I was done with the 6502, the x16 started to look more and more promising to me. So I started programming a Sokoban clone for the emulator, which I uploaded today. I first had to create some code to convert available sokoban (rosetta) ascii to a usable binary format. This binary is included with the program in a single PRG file, so it works in the web-emulator. When the final x16 hardware arrives, I'll create a version to let the user select their own levels.
Ok, enough about me. I'll be cheering the project on as best I can. Keep up the good work!
Jeroen
Gaaf!
