Parallax Demo
View File
This is an early concept based upon the ideas and code shown here https://www.8bitcoding.com/p/tiles-in-assembly-ii-line-interrupt-for.html
The PARA.PRG is my first attempt recreating the psudo parallax seen in games from the 16bit and 8 bit era. This is all on the same layer the same as in the above mentioned blog. The difference here was to make the background reactive to the foreground movement. Although this is hardcoded to move 1 pixel per frame forward all the slower sections are all based on how fast the foreground is moving.
I'm hoping to expand upon this to also support vertical perspective tricks.
Instructions:
copy the PARA.PRG file to your emulator location or run the x16emu from the files location.
run x16emu and type the following commands
LOAD"PARA.PRG"
RUN
Submitter
Submitted
03/07/21
Category
