New community dev tool uploaded: VTUI Library
JimmyDansbo
Post by JimmyDansbo »
VTUI Library
View File
VTUI (Vera Text User Interface) library
Can be used to create text user interfaces using VERA instead of relying on the KERNAL functions for writing to screen.
The library is less than 1KB which means it can be loaded into Golden RAM at $400. As an alternative, include files are provided for Acme and CA65 assemblers.
See https://github.com/JimmyDansbo/VTUIlib for documentation, examples and include files.
Visit my Github repo
ZeroByte
Post by ZeroByte »
Do you plan to make a C API for this as well?
It'd be great to have #include "vtui.h" and c functions for thee routines.
JimmyDansbo
It is not something I had thought about, but since you ask, I might look into it.
Would you be able to point me in a direction that explains what should be done to create a C API? I am guessing you are talking about cc65?
ZeroByte
Post by ZeroByte »
This might be a start.
https://cc65.github.io/doc/cc65-intern.html
It's what I've been looking at for doing the same, but with audio.
JimmyDansbo
Seems to be straight forward (said the blind mand) ?
Thanks. I will look into it.
