Getting SDL2 installed in cygwin
Mu0n
Post by Mu0n »
I haven't used a unix based OS in the last 20 years, so on top of being very rusty, I'm new to the whole package getting/updating through the internet. I used an already old X11 terminal back at my university between 2000-2002 and just did the bare minimum to compile my C physics code.
As an entry point to testing out the x16 emulator, I started watching SlithyMatt's excellent youtube series and followed the readme instructions on his repo here: https://github.com/SlithyMatt/x16-assembly-tutorial Note that I'm using a Win10 machine.
1) I installed cygwin with these packages ticked in during setup: git, gcc-core and make. I suspect that at this step, something needs to be done with SDL2 as well, as I hit a brick wall down below.
2) I went with symbolic links within cygwin rather than win10 path environment variables
3) I successfully git cloned, then compiled cc65, the x16 rom (I got a complain about not finding ld65.exe during that step, but I added the symbolic link to it as well, which made it work), but not the x16 emulator
4) Compiling the emulator gets me:
In file included from cpu/fake6502.c:107:
cpu/../debugger.h:15:10: fatal error: SDL.h: No such file or directory
   15 | #include <SDL.h>
 which leads me to think I'm not getting something fundamental with installing the SDL2 source within cygwin, a step for which most of you wouldn't bat an eye, but which baffles this mostly MS-DOS veteran.
I know I can download the emulator binary and rom and just forget about this step - though it's useful to constantly refresh versions with git. I know I can run code in the web emulator, but I want to understand where I'm going wrong and fix it, this will increase my unix knowledge and maybe help me elsewhere (ie raspbian on my pi3).
SlithyMatt
Post by SlithyMatt »
I don't know if a Cygwin build of the emulator itself will work -- I never tried that. There is the libSDL2-devel package, but I don't know if it will actually work. For Windows, I recommend using the release build of the emulator for Windows (which the dev team uses a Mac to build) and just use Cygwin for building and running cc65.
Ender
Post by Ender »
If you really want to compile it yourself in Windows for Windows, I've done it inside of MSYS, although I had to make some changes to the Makefile.  Compiling things for Windows is easier in MSYS than Cygwin because you don't have to worry about cross-compiling. If you're interested I could dig through what I've done and post more about it later (I mostly forget what I did off the top of my head).
