Updated Web Emulator
Yes the manifest generator certainly does atm. The emulator(s) don't, at least not for data files. Because everything works when I start Brixx in the (web) emulator directly.
I'll ommit the manifest in the future again.
- Site Admin
And for security reasons I've added a whitelist option to our server code that only allows certain extensions. Don't want someone to upload a .php file that can then be run straight from the server, right? So we're super doubly careful about extensions. BIN for all loadable assets is something I fully support.
yes, that makes sense, especially for the web emulator. I'll change the program, assets and ZIP file accordingly :-).
@MattGrandis
Could you maybe add SEQ, REL and DAT to the whitelist later? Those were quite common on the C64. At least for saving user data (high-scores, other databases etc).
Hm... how are we going to handle this in the web emulator? I assume not at all, that would be a massive security vulnerability...
SEQ and DAT especially for sequentially read/written text and binary data respectively.
REL was more for relative files, which I used quite extensively back in the day, since the C64 version of fig-Forth I used in the 80s used relative files for block files.
- Site Admin
Those standard extensions should be working.
Truly wise and secure. Thumb up! How about adding a note about this in the upload file form?
Thanks. We're trying to avoid additional work to the site at this time, as it all takes time and money. Bug fixes excepted of course. Otherwise, it's pretty much feature locked. ??
@SebastianVogesAny plans to update the emulator behind the "Try Now" button with the latest r38 version ?? My latest game makes use of the sprite collision interrupts which are not available in r37.
- Site Admin
That would be my job. Is the web emulator on version r38 already?
