hstubbs3
Post by hstubbs3 »
Funkheld
6502 CPU only has few registers... Accumulator (often called A), X and Y.. each is 1 byte - 0 to 255..
Multiple instructions allow indexing into memory using X or Y register ...
Actually, I gave some example of that in the other forum post, where you had asked about prog8 to save/load the current screen..
This bit here - uses X as a counter to track pages, y to index each byte of the page, and ZeroPage_PTR is 2 consecutive bytes in zero page of RAM ( $0000-$00FF ) set to some address like $HH00... the start of a page of memory..
LDX #num_pages
LDY #0
: LDA DATA0
STA (ZeroPage_PTR),y
iny
BNE :-
INC ZeroPage_PTR+1 ; this bit right here or you'll only keep overwriting that first page you're trying to write too.
DEX
BNE ;--
random index into array > 256 requires altering the highbyte... one _could_ create an array of arrays to manage the high byte themselves... IE say for 60 lines on screen, make an array sized 120 (60*2 bytes) to hold pointers to arrays with 160 bytes each (80 characters across the screen, char code + color data )
Then ... what line do you want? ... say 31... double it => 64 ... get bytes 64 and 65 into your pointer / memory address ... that would be the array to index for the other data ..
or if the arrays always start at beginning of page, would only need 1 byte for the first array, and access via the setting some ZP to $HH00 to index... but in this example, that would waste 96 bytes per line in memory...
(that bit -might- be more for desertfish to consider supporting a '2d' array of X pages... maybe in a way to span banks??? they are writing a compiler alone... it may be a bit much to ask )
I had provided some code for saving/loading the screen - maybe someone here could fill in the vars and such I wasn't sure on??
viewtopic.php?t=7266
sub screensave() {
ubyte *SAVEDSCREEN $someaddress_in_RAM ; // set the pointer here
for y1 in 0 to 60 {
cx16.vaddr_autoincr(1, VERA_TXTSCREEN + y1*$0100, 0, 2)
for x1 in 0 to 79 {
*SAVEDSCREEN = cx16.VERA_DATA0;
SAVEDSCREEN++;
sub screenload() {
ubyte *SAVEDSCREEN = $someaddress_in_RAM ; // set the pointer here
for y1 in 0 to 60 {
for x1 in 0 to 79 {
cx16.VERA_DATA0 = *SAVEDSCREEN ;
SAVEDSCREEN++;
funkheld
Post by funkheld »
Hello, thank you very much for the quick information.
Now I'm going to go to sleep and I'll work on it tomorrow.
Thank you.
greeting
Important Prog8 version 10.2 released
:!: Prog8 version 10.2 has been released
https://github.com/irmen/prog8/releases/tag/v10.2
The most important change is that the compiler now treats booleans much stricter than before. No longer 'equivalent' to a byte 0 or 1. You'll need an explicit cast to convert between bytes and booleans now.
If you are using conditionals like "if integervariable {....}" you'll have to make it into a boolean comparison expression like so "if integervariable!=0 {....}" .
For all the gory details read the release notes on the github release page.
funkheld
Post by funkheld »
hello, thank you for version 10.2
What a great job you're doing, great.
:D :D :D :D :D
Thanks.
greeting
Important version 10.2.1
Prog8 version 10.2.1 is released https://github.com/irmen/prog8/releases/tag/v10.2.1
Unfortunately a rather severe error was found after the 10.2 release, in the code generator for logical expressions (and/or). This is now fixed.
PS the error was already present since version 10.0, just not discovered until now...
funkheld
Post by funkheld »
hello thanks for info.
greeting
Important version 10.3 released
:idea: Prog8 version 10.3 has been released: https://github.com/irmen/prog8/releases/tag/v10.3
There's a change in this version that's not backwards compatible with older code, so it may be required to make some simple changes:
It is now possible (and required) to assign all values returned from a romsub/asmsub that returns multiple values.
The void keyword can now also be used in a new way: as a dummy assignment target for any value you are not interested in in such a multi-value assignment.
Please read the documentation in the manual for details about this new feature: https://prog8.readthedocs.io/en/latest/ ... ultiassign
funkheld
Post by funkheld »
hello, thank you for the new version.
greeting
BrokenAnsible
Post by BrokenAnsible »
This is such a great project. Thank you!
Version 10.3.1 released
Prog8 version 10.3.1 has been released
https://github.com/irmen/prog8/releases/tag/v10.3.1
This is a small update release to correct a few problems in 10.3, and a couple of easy changes. It's going to be the last release for a while because I need a summer break :) Other stuff and more complex bug fixes have to wait until after summer!
Library changes:
  • cx16.mouse_pos() now returns the mouse coordinates as unsigned words
  • cx16.mouse_pos() and cx16.mouse_get() now also return the scroll wheel position as extra return value in X
  • cx16: added diskio.f_tell()
  • added cx16.scnsiz (extapi call)
Other stuff:
  • added @nozp tag for variables that should never be placed into zeropage
  • miscellaneous bug fixes and documentation improvements
  • included a "profiler.py" script to process the emulator's new -memorystats dump file to see what parts of your program run the most
