Good to hear there is a solution
Maybe a good idea to post on the forum which snes controllers you purchased didn’t work with x16, so others can be aware.
Norton Commander for x16
Re: Norton Commander for x16
I found this in the Commander X16 Quick Intro FAQs for Setup by Voidstar:
While the inexpensive "under $10" SNES gamepads do work - I've found that a lot of them might only partially work on the X16. Specifically, for a great many of them, the SELECT button seems to be interpreted as always being pressed. For this reason, we can't point to a single SNES Gamepad vendor and say use that one. Even the sources that those vendor use might be inconsistent on which ones have issue or not.
This is what I ran into with the first SNES wired game controllers I purchased from Amazon. I purchased the Scout wireless SNES from the Micro Center and, once charged, works great. I've included pictures so you can avoid the bad ones I got.
This will get us started in identifying bad and good SNES controllers.
Thanks for the help,
Gerry
Gerry
- Scout SNES.jpeg (1.25 MiB) Viewed 1032 times
- Bad SNES Box Front.jpeg (1.41 MiB) Viewed 1032 times
actualy you can fix the select issue by adding a 1k resistor at the right place
quote from stefan wessel on discord
I tested it myself too.
I added a 1K resistor between the left side of R1 and pin 11 on the IC (3rd from the bottom right hand side) and that solved the issue
Before this drags out more, this is the Norton Cmdr. thread. Please start a new thread if you want to prolong SNES discussions. Thanks.
