Emulator r39 Released
svenvandevelde
Post by svenvandevelde »
Bingo! Got it working now! So new interrupt vector at $0314 has value $E040.
svenvandevelde
Any known issues with the mouse pointer? It seems the mouse pointer "get" api at $FFB6 is not working as expected.
Maybe I'm wrong, i baseline the mouse vectors to be returned at $22, which should be available to the user, right?
But it's not working. No mouse movement ...
ZeroByte
Post by ZeroByte »
Has cc65 updated the repo yet to be R39 compliant?
No.   cc65's cputc(), cputs(), and cprintf() appear to be non-working for X16.r39.  Text frame address change?
Michael Steil
Post by Michael Steil »
On 3/30/2022 at 6:44 PM, svenvandevelde said:
And the interrupt return vector has changed also ?.
Where was that again ... address vector in $0314 ....
let me check ... E040?
The location of the default IRQ handler is not API and must not be relied on. It changes in every single revision of the ROM.
Read the current value in your code, and jump to it at the end.
Michael Steil
$FF6B
svenvandevelde
On 3/30/2022 at 8:23 PM, Michael Steil said:
$FF6B
Typo, you are correct, i meant to write $FF6B
So this code seems to be correct.
This is the API call fragment:
However, the zero pages $22, $23, $24, $25 stay 0, regardless if I move the mouse or not.
I"m sequently calling this CX16_MOUSE_GET continuously.
I've attached a demo prg with source code in asm.
cx16-mouse.prgcx16-mouse.ccx16-mouse.asm
There's been a change in the mouse_config() API  https://github.com/commanderx16/x16-docs/blob/master/Commander X16 Programmer's Reference Guide.md#function-name-mouse_config
However I think there's also a bug.   Setting X and Y both to zero seem to reduce the 'screen size' to 0 by 0 blocks instead of keeping the 'current' resolution as the documentation now says.
I find that if you set them to 80 and 60 respectively, or perhaps follow the code snippet given in the docs, the mouse moves again.
Also there is a small error in the documentation, it still says "Communication registers: .A, .X" , this should be   "Communication registers: .A, .X, .Y" now.
Michael Steil
0 does keep the current size config. It's just that if you never called mouse_config before, the current config is 0x0, which it will keep.
@svenvandevelde, you need to call mouse_config, like in the example in the docs.
Michael Steil
Pull request, please? ?
