Compact X16?
Compact X16?
On 2/8/2021 at 2:18 PM, kelli217 said:
(macadamiaman via Wikimedia)
Quite. That was the system that I wrote a brute force maximum entropy estimator in C for my dissertation ... which took FOREVER to run. It would have been much faster using an annealing algorithm, but I couldn't wrap my head around that one.
I couldn't afford to keep it in batteries to make it "portable". I was able to run it off my car's cigarette lighter to make it car-mobile, but as I said, at the expense of leaving my external parallel port hard drive at home.
Kalvan
Compact X16?
Post by Kalvan »
I realize this may sound like a really dumb idea, but...
How about, when the time comes to engineer the Commander X16c, the team simply doubles the motherboard layer count, puts chips on both sides of the PCB, and, on the side facing up, use PC Card slots with some customized pinout for expansion?  It should permit more hard silicon and ASICS from its big brother onboard, and thus be more hackable for those who prefer it that way while still being a better fit in a keyboard-console or even laptop form factor.
Or maybe I'm totally off base.
Compact X16?
Because "c" stands for both "compact" and "cost reduced". Swapping to surface mount versions of the 65c02, VIAs, SRAM, flashROM, integrating the surface mount VERA system into the same board, replacing all of that glue logic with a CPLD and going with one slot, with optional riser board expansion to two or four slots would get the cost down.
The hackable one is the " p" one. The lowest cost one, period, and also the one that might fit into a keyboard case is the "e" one. The lowest cost version of the one with a real 65xx processor is the "c" one.
Perifractic
Compact X16?
Post by Perifractic »
Sounds like you’ve been watching Halt and Catch Fire.
Perifractic, X16 Visual Designer
http://youtube.com/perifractic
calcmandan
Compact X16?
Post by calcmandan »
ive been hoping ben heck would eventually craft a commander laptop.
Sent from my SM-T720 using Tapatalk
Kalvan
Compact X16?
Post by Kalvan »
A little, but even more various electronics channels on YouTube.
Personally, I was more partial to Micro MenSilicon Valley, and Computer Geeks.
Cyber
Compact X16?
Post by Cyber »
5 hours ago, Kalvan said:
Computer Geeks
I watched the other two, but what's this one? Can't find any info on it.
codewar65
Compact X16?
Post by codewar65 »
We could have a prototype ready for Comdex 2021!
Falken
Compact X16?
Post by Falken »
If I may ask @Perifractic, what do you model the casing on? I mean on what chassis. Do you also work with a vendor like you do with the keyboard for the casing?
I was very surprised to know that Perrix is also a german company. Maybe I should get one of their keyboards to have a look at in advance. :-)
calcmandan
Compact X16?
If I may ask [mention=3]Perifractic[/mention], what do you model the casing on? I mean on what chassis. Do you also work with a vendor like you do with the keyboard for the casing?
you ought to visit perifractic's youtube. he goes indepth
