VTUI library
VTUI library
prog8's textio module is a mess in this regard, some routines use kernal others write directly to Vera. Mostly, the operations that can reasonably be done by a kernal routine are not writing to Vera though. (On the C-64, it is the same, but instead of vera it directly writes into the screen buffer ram locations).
In the end, does it matter? It should be a secret for the user of the library how it does its work, as long as you get the desired result ?
The only thing that may be problematic is if you have banked out the kernal rom in your program and try to use the library routines that depend on a kernal routine. A note in the documentation about this should fix that I think (something I haven't yet taken care of for prog8...)
VTUI library
I'm using VTUI for a game at the moment ?
- JimmyDansbo
- Contact:
VTUI library
Which game is that? Have I missed it?
Visit my Github repo
VTUI library
No, I've just started making it a few days ago. Here's a little preview of what I've got so far:
edit: ripped out the keyboard control and replaced it with joystick control. But having a bit of a problem getting the buttons state in a reliable fashion atm.
- JimmyDansbo
- Contact:
VTUI library
New version uploaded to support R39
