How to implement bareback interrupts?
Re: How to implement bareback interrupts?
I can try to fix if you upload the complete source code file here + the ca65 config file
I have a minimal example that works in the emulator.
File: cart.cfg
MEMORY {
    ZP:             file = "", start = $0022, size = $0080 - $0022, define = yes;
    CARTRAM:        start = $1000, size = $8f00, define = yes;
    CARTROM:        start = $c000, size = $3fff, fill = yes, fillval = $aa;
SEGMENTS {
    SETUP: load = CARTROM, type = rw, define = yes;
    CODE: load = CARTROM,  run = CARTRAM, type=rw, define=yes;
File: main.asm
; Build with: cl65 -o cart.bin -t cx16 -C cart.cfg main.asm
.import __CODE_LOAD__
.import __CODE_SIZE__
.import __CODE_RUN__
IRQVec = $0314
.segment "SETUP"
; Magic cartridge string at $c000
.byt "cx16"
; Copy code to RAM
init:
    lda #<__CODE_LOAD__
    sta $22
    lda #>__CODE_LOAD__
    sta $23
    lda #<__CODE_RUN__
    sta $24
    lda #>__CODE_RUN__
    sta $25
    lda #<__CODE_SIZE__
    sta $26
    lda #>__CODE_SIZE__
    sta $27
loop:
    lda ($22)
    sta ($24)
    inc $22
    bne :+
    inc $23
:   inc $24
    bne :+
    inc $25
:   lda $26
    bne :+
    dec $27
:   dec $26
    lda $26
    ora $27
    bne loop
    ; Jump to RAM code
    jmp __CODE_RUN__
.CODE
hello:
    ; Select Kernal ROM bank
    stz $01
    ; Print hello
    ldx #0
:   lda msg,x
    beq _setup_irq
    jsr $ffd2
    inx
    bra :-
msg:
    .byt "hello",0
; Your code...
_setup_irq:
    ;nop
    ;php
    sei
    lda #<loop_irq
    sta IRQVec
    lda #>loop_irq
    sta IRQVec+1
    cli
    ;plp
    ;lda #1
    ;sta $9F27
    ;rts
wait:
    bra wait
loop_irq:
    jsr handle_clock
    jsr handle_joystick
    jsr handle_keyboard
    jsr show_life
    lda #1
    sta $9F27   ; ISR, bit 0=VSYNC
  	ply
	plx
	pla
    rti
handle_clock:
    ;inc $22
    rts
handle_joystick:
    rts
handle_keyboard:
    rts
show_life:
    inc $22
    bne :+
    lda #'.'
    jsr $ffd2
:   rts
Run with: ./x16emu -cartbin cart.bin
Looking at this code that you posted earlier, one thing that stands out is the PLP at the end of _setup_irq. This will disable interrupts, if interrupts were disabled at the beginning of the function, effectively overwriting the CLI.
_setup_irq:
    nop
    php
    sei
    stz ClockLo
    stz ClockHi
    lda #<loop_irq
    sta IRQVec
    lda #>loop_irq
    sta IRQVec+1
    ; Setup first VBLANK
    lda #$1
    sta VERA::IRQ_EN
    cli
    plp
    rts
loop_irq:
    jsr handle_clock
    jsr handle_joystick
    jsr handle_keyboard
    ; Sign IRQ
    lda #$1
    sta VERA::IRQ_FLAGS
    ; Cleanup
  	ply
	plx
	pla
    rti
kliepatsch
Post by kliepatsch »
This is starting to smell like a bug in the emulator. Maybe the fact that a cartridge is inserted changes its behavior? I think that ISR with a cartridge has so far been rather niche and maybe not been tested very well.
Edit: from skimming through the emulator source I can't find anything suspicious. It seems to be exactly as Stefan explained.
kliepatsch
Ah yes, good find Stefan. Didn't see your posts before posting mine
SunSailor
Post by SunSailor »
Boah, thanks guys, you rock! Stefan, you're right, that's the issue. Would never found that, although I still don't understand, why everyting worked fine on the vanilla boot then. I was so focused on the VERA flag set, that I totally forgot about the CPUs one.
For the sake of anybody ever searching for something like this, this is the working code on my side now:
_setup_irq:
    nop
    php
    sei
    lda #<_loop_irq
    sta IRQVec
    lda #>_loop_irq
    sta IRQVec+1
    lda VERA::IRQ_EN
    ora #$1
    sta VERA::IRQ_EN
    plp
    cli
    rts
_loop_irq:
    ; Sign IRQ
    lda #$1
    sta VERA::IRQ_FLAGS
    ; Cleanup
  	ply
	plx
	pla
    rti
Without digging deeper it's hard to be sure, but I have at least a theory why it first worked, and not in the cartridge ROM.
When the boot_cartridge function is called during Kernal init from within the start function in kernal/cbm/init.s, interrupts have been disabled with a SEI instructions. When you in the cartridge setup function preserved and restored the status register, you kept interrupts disabled.
If the same setup function is called from BASIC, where interrupts are enabled, you are not hit by this.
As a side note:
php
sei
<do some work>
plp
is a common pattern in 6502 assembly when you need to disable interrupts but want to preserve the original state of the interrupt flag.
SunSailor
Post by SunSailor »
Ah, that makes totally sense! Thank you, for pointing this out!
