SPLASH Screen & Startup Sound.
Re: SPLASH Screen & Startup Sound.
Here's a fun one for those who like to make their startup look like a different computer.
MacSplash.zip
(17.9 KiB) Downloaded 120 times
oodler
Post by oodler »
I had to figure out how to do the audio. My solution was to:
1. used "yt-dlp -k" to keep the .mpa audio from a youtube rip
2. used an online mpa to wav converter
3. installed audacity and used it to clip the audio, then https://www.youtube.com/watch?v=Yq3xjaQkAPg to figure out how to output it properly to mono WAV
Enjoy!
K.I.T.T.zip
(1.73 MiB) Downloaded 115 times
Audacity is a VERY versatile program. There's no need to extract the Audio from a Youtube rip first... Audacity can just directly open the Video file, it will do the sound track extraction all by itself.
Also Stereo WAV's will also work, however you do need to lower the sample rate to 32000 hz or lower (22050 usually sounds fine).
oodler
Post by oodler »
ahenry3068 wrote: Tue Aug 20, 2024 8:58 am
Thank you!
Saw this one and found it very amusing. Sound was my idea but it follows naturally from the Image.
Requires Splash Screen app from top post.
Screenshot from 2024-08-30 03-13-03.png (57.22 KiB) Viewed 963 times
HERES YOUR COW :roll:
COW.zip
(112.78 KiB) Downloaded 84 times
ahenry3068 wrote: Fri Aug 30, 2024 7:15 am Screenshot from 2024-08-30 03-13-03.png
DO have a cow, man!
NEW Splash Screen US Robotics
Heres a new one.
(Requires app from Top Post)
Screenshot from 2024-09-23 18-36-35.png (36.13 KiB) Viewed 269 times
AND HERE'S THE SPLASH SCREEN
MODEM.zip
(560.2 KiB) Downloaded 26 times
