Yes. The emulator uses the exact ROM that would be used on the hardware. To upgrade the ROM on the emulator you would download the latest from GitHUB. Build it (with make) then either copy it over the rom.bin in the Emulator directory (not recommended immediately)funkheld wrote: ↑Sun Mar 10, 2024 8:54 am --------------------------------------------
GRAPH_draw_image in the latest ROM on github IS "Banked RAM aware" and can handle image size
in Banked Ram all the way to 320 x 240
Does this also affect the x16 emulator please?
Thanks.
greeting
You can also start the Emulator with a different ROM ./x16emu -rom NewRom.bin
