Limitations of RND() function
That's because the program must now be started from the command line with the switch -rtc in order for the real time clock to function and produce the data for use in TI$.
(IMHO, the RTC being active should be the default state of the emulator—and I'm guessing that it probably will be, once Michael has verified that it works properly and conforms with the behavior of the real hardware.)
