Emulator r38 Released
Every release feels like christmas. THANKS Michael Steil and everyone that have contributed! And a special thanks to @StephenHorn for the improvements to VERA! I have really been waiting for raster line and sprite collision interrupts!
Great also that WAI is now implemented. I actually thought it worked already. I have been using it for quite a long time but the code must just have resulted in a busy wait... This must be the answer to why WAI (sorry, trying to be funny) has been so slow in response.
Can someone tell me what Chars are that on a DE Keyboard layout?
Ctrl
and Ctrl
will toggle warp mode.I have no clue how to enable warp mode or how to identify I am in warp mode. Any idea?
5 minutes ago, SerErris said:
Can someone tell me what Chars are that on a DE Keyboard layout? I have no clue how to enable warp mode or how to identify I am in warp mode. Any idea?
Try ß, +, -, = ... those keys near the backspace key... If you're okay with warp mode being enabled for the whole session, you can specify -warp on the command line.
If it really doesn't work on non-US/ISO keyboards, I can change the shortcut to something else in the next release. In this case, file an issue on GitHub against x16-emulator.
Hmm ... according to this picture the US keyboard has the + and = at the same key ... just shifted.
On a German keyboard this is the "´" key and the "`" key. The later one is with SHIFT. The documentation should better read CTRL-= and CTRL-SHIFT-=
It works ... however the same key is in X16 the "UP ARROW" key.
Great progress!
The following C code example works with cc65 for writing/reading files with an sdcard image attached to the emulator. If the load/vload worked as well I could add a logging capability to libX16 that would let a program do debug logging to a file for debug purposes. I'd love to support something like that for the host filesystem interface as well someday.
#include <string.h>
#include <stdio.h>
#include <cbm.h>
#define MAX_BUF_SIZE 80
int cbmwritefile()
char data[80];
int ssRet=0;
char ucDev=8;
char filename[20];
int len=0;
strcpy(data, "this is just an example text.");
len=(int)strlen(data);
strcpy(filename, "@0:cbmdata,w");
ssRet = cbm_open(2, ucDev, CBM_WRITE, filename);
if(! ssRet)
if(data != NULL) {
if(len >= MAX_BUF_SIZE) {
len=MAX_BUF_SIZE;
data[MAX_BUF_SIZE]='\0';
cbm_write(2, &len, 2);
cbm_write(2, data, len);
} else {
printf("writing file '%s'\r\n", filename);
else
printf("**error - can't write file: '%s'", filename);
cbm_close(2);
return ssRet;
int cbmreadfile()
int ssRet=0;
char ucDev=8;
char buffer[MAX_BUF_SIZE];
char filename[20];
int flen=0;
strcpy(filename, "@0:cbmdata,r");
memset(buffer, 0, MAX_BUF_SIZE);
ssRet = cbm_open(2, ucDev, CBM_READ, filename);
if(! ssRet)
cbm_read(2, &flen, 2);
cbm_read(2, buffer, flen);
printf("reading file '%s'\r\nlength: %d [ %d max.]", filename, flen, MAX_BUF_SIZE);
printf("\r\ntext : %s\r\n", buffer);
else
printf("**error - can't read file '%s' ", filename);
cbm_close(2);
return ssRet;
int main()
int ssRet=0;
printf("** filetest 0.2 stdio.h / cbm.h **\n");
printf("calling cbmwritefile()\r\n");
ssRet = cbmwritefile();
printf("err: %d\r\n", ssRet);
printf("calling cbmreadfile()\r\n");
ssRet = cbmreadfile();
return 0;
- StephenHorn
- Contact:
I'm not a Mac guy, but is it possible Scott is missing something like C development libraries or something? Could/should they try installing GCC or something?
The answer to "should I install gcc?" is always YES
