Proposal for Expansion Card Connector
martinot
Re: Proposal for Expansion Card Connector
Post by martinot »
I think it is a great idea to use the Apple II bus and to be able (after writing software) all the hardware cards created. Would be a massive boost för the X16!
Thread necromancy!
The expansion slot is now fixed in design. It's a 60-connector slot.
Here's more information: https://github.com/X16Community/x16-doc ... ardware.md
Thanks, Kelli.
Yes, the design is now set in stone. Apple II cards aren't going to work, much for the same reasons Commodore 64 cartridges would not have worked: this system runs at 8MHz, and the logic to make a cart work at 1MHz while the rest of the system works at 8MHz is prohibitive.
However, if you want to build a Commander-Apple bridge board, that would be a great feature.
