Beware of using the VERA inside IRQ
AndyMt
Post by AndyMt »
18 hours ago, The 8-Bit Guy said:
And the IRQ can run right in the middle of your writes to VRAM.
Ah - this is why the sound effects in Invaderz sometimes drop out or chip in some way... I can now fix this, thanks a lot!
StephenHorn
Post by StephenHorn »
My solution to this was to generally run all of my logic in the IRQ, starting with screen draws, while the non-interrupt code essentially spins on a tight loop checking on a single memory address. This way I don't have to worry about any of my routines being interrupted. An additional up-side to this is that I effectively have a thread that's not doing anything, and I'm thinking it would be ideal to place my streaming I/O logic into there, essentially spinning through banks and loading files as needed into them.
In particular, I really like the VERA's dual access channels and auto-increment settings, and how they make it really easy to write columns and rows of 16-bit tile data.
paulscottrobson
Post by paulscottrobson »
Might be quicker to semaphore it, so when your code isn't updating Vera you don't have to execute the code if it hasn't claimed the semaphore. Really depends :)
There's an argument that you shouldn't update in IRQ anyway, but have a Model-View design, so you update your model if you want in the interrupt routine, just using the IRQ as a timer.
