6 minutes ago, Elektron72 said:
It was a while ago, and I believe I may have deleted the test program since then. When it ran, there would be flickering between the desired appearance (a darker version of the text layer), the original text layer, and the black background color. I might try and rewrite the test at some point in the future.
Well, it is important that the emulator be running at full speed for an effect like that, but even a small timing glitch could cause flickering behavior, such as the thread being put to sleep for too long, or a particular frame taking unexpectedly long to execute.
While an alpha channel isn't conceptually impossible to add to the VERA at some point, some of the real question is whether it can be fit into the FPGA's remaining logic units without having to shave functionality from somewhere else. On the technical side, it's worth pointing out, as well, that you probably don't want the alpha to apply to individual colors in the palette. But even if you did, what about layer and sprite alphas for fading out individual elements which may share palette colors with something else on the screen? And how would that potentially interact with an alpha channel on palette entries?
Having alpha in the color channels also places a much greater emphasis on Z-ordering, in particular where sprites are concerned*. I suppose that's not a problem if you're calculating your own Z order and clobbering all sprite data every frame in order to apply it, but that sounds expensive. I haven't timed it out, I'm just saying that my gut instinct is to avoid that practice for more than a handful of sprites, if possible.
* The Z-order of transparent objects determines which alpha channels have the greatest contribution to final color, with the smallest contribution coming from the object furthest in back. Transparency is a big deal in graphics programming, there have been a lot of papers written to try and solve various transparency-related problems in 3D graphics. Realistic "smoke" and "fog" effects, in particular, are extremely hard to make look good in a variety of circumstances, and lot of it has to do with Z-ordering issues. Perhaps one of the biggest appeals of realtime RTX on the latest generations of GPUs is that you don't have to worry (as much) about variously-expensive transparency effects, because you can choose to ray-trace instead.
