VTUI library
JimmyDansbo
VTUI library
Post by JimmyDansbo »
Does anyone use the Acme or Ca65 include files for the VTUI library?
I ask because I am contemplating a restructure that probably will mean significant change in the include files...
Visit my Github repo
VTUI library
I am using the assembled BIN file only, so no impact for me
JimmyDansbo
VTUI library
Library updated to version 0.7
Only real usage change is that print_str no longer accepts a zero-terminated string. Instead the length of string is provided in .Y also a lot of the functions can now skip color information if VERA stride is set to 2.
VTUI library
aw... this now means for Prog8, that I have to iterate strings twice to print it (once to determine its length based on 0-termination, and then again in VTUI while printing it).  It is what it is, I suppose. At least for constant strings I always know the lengths beforehand.
JimmyDansbo
VTUI library
I am sorry for the inconvenience, but since print_str supports writing screen codes directly, we can not use a value as termination as all 256 bytes are occupied by characters.
@desertfish, I could possibly support zero-termination if the string is converted... Would that help?
VTUI library
That makes sense... I actually don't have a proper way of dealing with screencode strings in Prog8 that require a zero character. It's always the terminator.
As for supporting it for converted strings: it would help a bit, but I think it's best to have a consistent API over sometimes supporting it and sometimes not supporting it (which could lead to confusion)
SlithyMatt
VTUI library
Post by SlithyMatt »
NULL is still NULL, there is no other control character mapped to zero. You should be able to use null termination, no problem. Doing a CHROUT with NULL has no effect.
JimmyDansbo
VTUI library
When we are talking screencodes in VERA, 0 = @
So a zero-terminated string that is not converted from petscii to screencodes would not be able to write the @ sign.
SlithyMatt
VTUI library
Ok, it wasn't clear that you were talking about screen codes. Yeah, in that case you don't have a safe terminating character.
VTUI library
A counted string that was converted FROM screencodes could be converted to one that was nul terminated. Then its the screencode converting routine that takes the count, not print_str.
