VTUI library
- JimmyDansbo
- Contact:
VTUI library
Does anyone use the Acme or Ca65 include files for the VTUI library?
I ask because I am contemplating a restructure that probably will mean significant change in the include files...
Visit my Github repo
VTUI library
I am using the assembled BIN file only, so no impact for me
- JimmyDansbo
- Contact:
VTUI library
Library updated to version 0.7
Only real usage change is that print_str no longer accepts a zero-terminated string. Instead the length of string is provided in .Y also a lot of the functions can now skip color information if VERA stride is set to 2.
VTUI library
aw... this now means for Prog8, that I have to iterate strings twice to print it (once to determine its length based on 0-termination, and then again in VTUI while printing it). It is what it is, I suppose. At least for constant strings I always know the lengths beforehand.
- JimmyDansbo
- Contact:
VTUI library
I am sorry for the inconvenience, but since print_str supports writing screen codes directly, we can not use a value as termination as all 256 bytes are occupied by characters.
@desertfish, I could possibly support zero-termination if the string is converted... Would that help?
VTUI library
That makes sense... I actually don't have a proper way of dealing with screencode strings in Prog8 that require a zero character. It's always the terminator.
As for supporting it for converted strings: it would help a bit, but I think it's best to have a consistent API over sometimes supporting it and sometimes not supporting it (which could lead to confusion)
VTUI library
NULL is still NULL, there is no other control character mapped to zero. You should be able to use null termination, no problem. Doing a CHROUT with NULL has no effect.
- JimmyDansbo
- Contact:
VTUI library
When we are talking screencodes in VERA, 0 = @
So a zero-terminated string that is not converted from petscii to screencodes would not be able to write the @ sign.
VTUI library
Ok, it wasn't clear that you were talking about screen codes. Yeah, in that case you don't have a safe terminating character.
VTUI library
A counted string that was converted FROM screencodes could be converted to one that was nul terminated. Then its the screencode converting routine that takes the count, not print_str.
