New demo uploaded: quick sort color demo
x16tial
Post by x16tial »
View File
Variation of the quick sort demo, but this one using the 320x240x8bpp mode, which uses double the memory, and is that much cooler to watch ?
Tap any key to progress from:
  • Random
  • Slowed down sort
  • Random
  • Full speed sort
  • Back to Basic
Note: that band of "non random" pixels below the middle of the screen is the default location of character tiles at $0f800 = $0ffff.  This gets moved to right after screen memory at $04000 - $047ff (which is probably where it *should* default to, if you ask me :))
what RNG are you using to set everything back to random?
x16tial
Post by x16tial »
entropy_get ($fecf)
then I just use part of the routine in the example in the doc:
JSR entropy_get
STX tmp ; combine 24 bits
EOR tmp ; using exclusive-or
STY tmp ; to get a higher-quality
EOR tmp ; 8 bit random value
Then STA that value into mem
The doc recommends that "this data should be fed into a pseudo-random number generator" but it seems to work well enough.
x16tial
Post by x16tial »
Just added "sortdemocolor2.prg"
This one will pause at each "level" of the sort, kinda fun to see how the colors separate at each level.
Will have to be downloaded to use it, as the "Try it now" button in the download dialog runs the original.
