VTUI library
Greg King
VTUI library
Post by Greg King »
On 2/18/2021 at 3:16 PM, JimmyDansbo said:
I think it is a very good idea to give the option of having print_str not convert anything, and I believe that it should fit.  Thanks for the suggestion (I had actually thought of it, but forgot about it again).
edit: I have made the change, and it takes up only 2 bytes. ?
You can use the bit instruction to reduce the size of that macro.  First, change the flag to be
.A = Convert string (0 = no conversion, $80 = convert)
  Then, use
bit r2l
bpl +
  You won't need to save the .Y register.
Greg King
VTUI library
Post by Greg King »
In the VTUI_BORDER macro, you have
lda    r0h
sta    VERA_ADDR_M
inc    VERA_ADDR_M
You can increment the accumulator before you store it into that VERA register.
JimmyDansbo
VTUI library
Post by JimmyDansbo »
@Greg King thanks, I will look into it.
4 bytes saved, thanks again ?
Visit my Github repo
VTUI library
Did something break in print_str() in the 0.5 release?  My test program now crashes if I use that function. It worked fine with 0.4.  I made the change to load A instead of the Carry flag....
edit: looking at the code for it, I see there's a ldy r2h before the iny in the loop that looks like it should not be there?
Ender
VTUI library
Post by Ender »
Yeah, I noticed that too. The issue is, they removed "sty r2h" toward the beginning, without removing the "ldy r2h" toward the end.  Removing that should fix it.
The calls to vtui_print_str in the examples also need to be updated to set A to $80 instead of 1, but that's a separate issue.
JimmyDansbo
VTUI library
I was a bit premature in declaring the changes, Greg King suggested, a success ?
We should be back to normal operation now. As stated, I have removed the ldy r2h and I have changed the print_str function to convert from petscii if .A=0
VTUI library
Sorry to nag again but I think there's another new issue regarding the decoding of petscii strings.
Ignore the stuff below, the problem's caused by a bug in Prog8's string interning that I recently added and made a mistake in.
If I call the print routine like this (from prog8):
vtui.gotoxy(12,12)
vtui.print_str(@"Hello, world! vtui from Prog8!", $f2, $80)
vtui.gotoxy(12,13)
vtui.print_str("Hello, world! vtui from Prog8!", $f2, $00)
The first string is encoded in screencodes (because of the @-prefix) and will use the $80 parameter for print_str to not decode it.
The second string is encoded in petscii and will use the $00 parameter to let print_str decode it by itself to screencodes.
However something goes wrong now, have a look, it replaces/decode a lot of characters that shouldn't be touched...:
If I remove the first call to print_str,  and leave the rest  of the codeuntouched, the result is:
which is what I expected.
It seems that the routine has some internal state/status that carries over inadvertently across different calls.
Greg King
VTUI library
Post by Greg King »
13 hours ago, JimmyDansbo said:
We should be back to normal operation now. As stated, I have removed the "ldy r2h", and I have changed the print_str function to convert from petscii if .A=0
You should change the "INPUTS" description to show the new meaning of .A .
Greg King
VTUI library
Post by Greg King »
I don't see any persistence in that macro.
I think that the bug is in Prog8.  It looks as though Prog8 converted both strings to screen codes!  (Does Prog8 merge similar strings into a single copy?)
VTUI library
I am stupid, this is exactly what is happening! It's an optimization I recently added to the compiler and it looks like I made a mistake there ?   Thanks Greg for pointing it out.
It works fine now after a bugfix there:
