Here's what Concerto does with the voicing.
First off, terminology inside Concerto:
Oscillators correspond to the 16 voices of the VERA PSG. Every sound can use one or more oscillators.
Channels are the way Concerto organizes playback internally. There are 16 Channels. Each channel is monophonic, i.e. it hosts a single voice that is either active or inactive.
Voices refer to the notes that are played. Because each channel can host only a single voice, the two terms can often be used interchangeably. If you play a note on channel X, you automatically address voice X.
Each note-on event needs to specify
Channel
Timbre (which of the 32 synth patches to use)
Pitch
Volume
If a note-on event is issued, it is first checked whether there is already an active voice in the specified channel. If it is a different timbre than the one being played, the old voice is stopped and the new voice started. If the new voice has the same timbre as the old one, the voice is updated according to the "retrigger" and "portamento" settings.
Every time a voice is started, it is checked if there are enough oscillators available. If yes, they are taken off the list of available oscillators (and returned to it once the voice is stopped). If there aren't enough oscillators available, the note simply is not played. It can run out of oscillators.
There are two types of note-off events. Hard and soft ones. Hard note-offs (in the source code "stop_note") immediately deactivate the voice and return the oscillators to the free oscillator list. Soft note-offs ("release_note" in the source) trigger the release phase of all envelopes. As soon as the master envelope (the first one of the three) hits level 0, the voice is turned off automatically and the oscillators are returned to the free oscillators list.
Note-off events are simply communicated via the channel number.
Now I'd like to comment on a few things.
22 hours ago, m00dawg said:
Normally in a tracker, the channels and voices are 1:1 but when supporting multi-voice instruments, things are now not strongly coupled. Which I think is worth it, but means you could "run out" of voices. So yep having a way to see which voices are in use makes sense. Many trackers have this sort of feedback, though since voices == channels in those cases, it is a bit different than here. Something as simple as the equivalent of LEDs on a real synth showing which voices are active I think would be sufficient.
Yes, Concerto can run out of oscillators. And I agree some kind of visualization of how many are used seems reasonable.
I could imagine something in the direction of how Synth1 does it. See for reference
https://youtu.be/__2AFeG4xII?t=187
In the bottom right of Synth1 you see the 32 voices of the synth and which voices are currently active. Since the sound is making use of unison, it uses several detuned voices per note.
In our case, we would instead be displaying individual oscillators instead of voices (in the sense that a voice can employ several oscillators).
But your suggestion
On 1/17/2021 at 3:25 AM, m00dawg said:
So let's say I have something like:
ROW| VERA01 | VERA02 | VERA03 | ...
00 | C-4 01 | --- -- | --- -- |
01 | ... .. | ... .. | ... .. |
02 | C-4 02 | C-4 03 | ... .. |
Sort of hard to represent in text, but basically if instrument 01 allocates 3 voices, we disable channels 2 and 3 (represented by the dashes, though in a multi-color tracker, we would probably just dim or highlight them to indicate they are in use). Then when we use instrument 02 on channel 1, if it's a single voice instrument, we know channels 2 and 3 are available and can be used for other things (as in the example).
seems possible, too. This would suggest that the user directly chooses which PSG oscillators to use instead of letting the synth engine manage that. I'm not a big fan of it, but it would provide more control, especially if you combine it with the user being able to stop individual oscillators and reuse them, while other oscillators of a previous note are still going. This is what you said if I understood you correctly
It could even be possible to override one of the voices (say by placing a note on VERA02 at row 01 in the above example where instrument 01 might have a long tail), then their new note would take precedence. And actually likewise, if someone wanted to use a multi-voice instrument on channel 01 at row 00 and then put another instrument on channel 02 on the same row, channel 02 should override the voice.
So in other words, the UI could provide cueues to channel usage when using multi-timbral voices, but the composer can still do as they please if they want to override voices.
If you did this, you would need some restructuring of the current voicing system. You need to allow for the extra freedom to terminate parts of a multi-oscillator sound. Currently, all oscillators are released at the same time. This would change if you allowed for partial releases.
It's good to see that you are already on your way with 6502 machine language.
