New demo uploaded: C64 image file viewer (koala format)
View File
I wrote a program that loads Commodore-64 multicolor pixel art images in the "koala" file format, and displays them to a regular Commander X16  320x200 graphics screen.
The C64 uses a fixed palette of 16 colors for all its graphics.
I do find that the saturation of the default colors in de c64 palette in the Cx16 emulator is not very good though: when the images are displayed on a C64 or in an emulator like Vice for instance, they look much better in my opinion.
So the program sets a custom palette (the "pepto" Vic-II colors) to make the images look closer like they would on a C64.
This program has been integrated in a multi-format image viewer now, the source code of that is here https://github.com/irmen/prog8/tree/master/examples/cx16/imageviewer
AndyMt
Post by AndyMt »
I do find that the saturation of the colors in de c64 palette is not very good in the Cx16 emulator though: when the images are displayed on a C64 or in an emulator like Vice for instance, they look much better in my opinion.
I noticed that, too. In most colors seem to be too dark, a few too bright (Yellow if I recall correctly). Have you tried tweaking the palette for your viewer?
Other than that: great tool!
Tweaking the Vera's color palette was easier than I thought.
I've uploaded a new version that changes the color palette to the well-known 'pepto' Vic-II palette and the images look a lot better now
I'm going to take this a step further, and implement a sort of library to load various image formats.
So currently we have:
  • Koala paint C64 multicolor image (fixed size 160x200, 16 fixed colors)
I'm busy investigating:
  • BMP  (windows bitmap image files, various sizes, up to 256 colors, uncompressed),  have a Python prototype working
  • PCX (paintbrush image files, various sizes, up to 256 colors, very simple compression), have a Python prototype working
  • GIF (up to 256 colors, compressed) would be nice but perhaps the decompressor is too complex? I don't yet know how it works.
  • PNG (up to 256 colors, DEFLATE compressed)  requires zlib to decompress.   Have a Python prototype working.   6502 decompressor: see Andy's link below
  • IFF ILBM (Often used on the Amiga) Have a Python prototype working. No HAM support though
AndyMt
Post by AndyMt »
Gif can be unpacked using zlib if I'm not mistaken. And there is a 6502 implementation:
https://github.com/pfusik/zlib6502
@AndyMt ooh thanks for that link!! Actually, it's PNG that can be unpacked using zlib, which is even better!
