New community dev tool uploaded: Simplest Sound Effects Library for BASIC programs
On 8/31/2020 at 4:26 AM, DusanStrakl said:
Very cool! No I don't preserve registers.
OK, I've added PUSH, and PULL, to "comma" ("copy data into the current spot in the dictionary") whichever register storage to the hardware stack is required by the implementation.
I've only recently downloaded the CX16 emulator, and I don't have sound, but I'm pretty sure it will be straightforward. I don't touch interrupts at all at this point in Forth compiler development.
mobluse
Post by mobluse »
I tried both EFFECTS and EFFECTSHI with my program Aritm, but in both cases it deletes the screen and changes background color after the sound, and then you cannot see what you type. I use R38 of the emulator in most updated Windows 10.
I added these lines to Aritm:
10 IF PEEK($9000)=0 THEN LOAD"EFFECTSHI.PRG",8,1,$9000
3612 SYS $9000
10 IF PEEK($400)=0 THEN LOAD"EFFECTS.PRG",8,1,$0400
3612 SYS $400
DusanStrakl
Post by DusanStrakl »
Thanks for the comment Mikael. It seems that there was some interference between effects library and some VERA related actions from BASIC programs, specifically in your case, scrolling of the screen. I added some code to save and restore VERA state inside the IRQ Player. I tried both EFFECTS.PRG and EFFECTSHI.PRG with your program and it seems to work without problems now.
mobluse
Post by mobluse »
Yes, both EFFECTS and EFFECTSHI works for me in Aritm now. In order to use it with the "Try it now" button one would have to be able to upload disk images or have some way of including the sound effects library in a single file with my BASICv2-program. Edit: The "Try it now" button for Aritm with sound works now. I put both files in a zip-file and updated. It automatically selected the right file, but if it should choose wrong you can edit which file is the main program.
mobluse
Post by mobluse »
In the table EXPLODE and ZAP should switch places.
DusanStrakl
Thanks. Corrected.
mobluse
Post by mobluse »
On 9/25/2020 at 9:43 PM, DusanStrakl said:
Thanks. Corrected.
Yes, it's fixed in the first post here, but the table is still wrong on the file download page: https://www.commanderx16.com/forum/index.php?/files/file/62-simplest-sound-effects-library-for-basic-programs/
DusanStrakl
Darn it. Thanks, you have eagle eyes. I hope that is fixed now too.
paulscottrobson
Post by paulscottrobson »
Did you used to own an ORIC ?
DusanStrakl
Ha, ha, yes I did. It was my first computer. Anybody who did will know these four sound effects ?
