USR() function to sort BASIC string array
MarkTheStrange
Post by MarkTheStrange »
This is an implementation of Shell's sort designed to be called via USR() from CBM BASIC. In my testing it sorted 100 words in 3 jiffies, and 1000 in under a second.
The argument should be the address of the array's first element:
X=USR(POINTER(A$(0)))
There's a loader program which can be assembled and run to install the handler into golden RAM and point the USR vector to it; there's also a ready-to-go binary file (SHELLSORT.BIN) which can be BLOADed directly (you still have to point the USR vector at $0311-$0312 to it manually).
POKEDEMO.PRG
(2.75 KiB) Downloaded 54 times
shellsort.zip
Archive of source and executable code
(485 KiB) Downloaded 62 times
