set sprite to 256 colors.
funkheld
Post by funkheld »
hello, good day.
I would like to set the sprite to 256 colors.
how do I do that please?
thanks.
greetings
unartic
Re: set sprite to 256 colors.
Post by unartic »
If you have a sprite 16x16x256colors, you can add it like this:
indx = ADDSPRITE("sprite.bin",16,16,8,0)
The 8 meand 8 bits per pixel which corresponds with 256 colors.
funkheld
Post by funkheld »
hello, thanks for the info.
I couldn't place the "8".
greetings
unartic
Post by unartic »
I'll clarify this in the docs :-)
unartic wrote: Sat Aug 03, 2024 1:50 pm The 8 meand 8 bits per pixel which corresponds with 256 colors.
Unless there's a technical reason, it would be clearer if the actual color depth value could be used.
