unartic
Posts: 136 Joined: Sat Oct 28, 2023 3:26 pm
Post
by unartic » Sun Jul 28, 2024 7:04 am
nxtBasic 0.4b is now released and ready to download.
Whats new?
Bug fixes:
Fixed bug while playing multiple zcm-files in sequense
Fixed bug with GETBMXHEIGHT and GETBMXWIDTH
Fixed bug in custom keyboard handler
Fixed bug in the internals of string storage in ram, causing string space to be filled rappidly
Fixed bug reading from DATA blocks with negative integers
Fixed bug: READ() was disabled due to build in constant READ (for OPENFILE). READ and WRITE are renamed to FOR_READ and FOR_WRITE
Fixed bug in line draw routine, not restore vera to prev state correctly
Added:
CURROW() -> returns the current row the cursor is on
CURCOL() -> returns the current column the cursor is on
PushVar() -> push the contents of a variable to the variable stack
PullVar() -> pulls a value from the stack and assigns it to a variable
User defined functions: FUNCTION MyFunc() as String
User defined sub routines: SUB MySub()
New example programs:
player.bas: file browser which plays zcm and zsm files and shows bmx images
keyjoy.bas: demonstration of joystick and keyboard routines with multiple key presses simultaneously
https://github.com/unartic/nxtBasic
Posts: 281 Joined: Tue May 16, 2023 6:21 pm
Post
by mortarm » Sat Aug 03, 2024 12:42 am
funkheld wrote: ↑ Wed Jul 24, 2024 2:03 pm
...a new era is beginning now...(kamala harris...
What the Hell does that have to do with anything? Never mind, this isn't the place for politics.
unartic
Post
by unartic » Sun Aug 04, 2024 5:04 pm
nxtBasic 0.5b is now released and ready to download.
Whats new?
- Bug fixes
Fixed bug while checking length of string concatanation
Fixed bug when multiple lines seperated by a semicolon where places behind the THEN statement
Fixed bug in BLOAD function
Fixed bug in function/sub definition where there was as space in front of the argument.
Fixed bug in BANK and COLOR statement when not supplying the optional argument
- New:
Added CHAIN -> resume executing into another PRG-file.
Added "EXIT SUB" and "EXIT FUNCTION"
Added documentation on how to extend nxtBasic with your own assembly routines
Added DO/LOOP/EXIT LOOP
Added "OPTION EXPLICIT" to force declaration of variables
Added DIRITEMDATE(), DIRITEMTIME() and DIRITEMSIZE() to retrieve all file information
Added internal constants for 16 bit registers (r0,r1 etc) and vera-registers
- Improved:
Moved WorkBuffer and stacktable to end of low mem space
VERA FX multiplication output moved to non-visible piece of vram
ADDSPRITE can now also be called with an address instead of a filename to configure a sprite which is already in vram
ADDSPRITE returns the vram address a sprite is loaded into GETA(), GETX() and GETY()
Added ",FORCE" at the #INCLUDE directive to force an include, even if the file has been included before.
If BINPUT# is used to load less then 256 bytes, MACPTR is used to speed up the reading
Syntax checking for CONST definitions on compile time.
nxtBasic resets several internal memorylocation on run so running a prg several times should not cause an issue
Several performance improvements regarding sprite functions
25% performance improvement on FOR-NEXT loops when there is no STEP defined.
Docs and download:
https://github.com/unartic/nxtBasic/ or
https://nxtbasic.com/
unartic
Post
by unartic » Tue Aug 20, 2024 7:23 am
nxtBasic 0.6b is now released and ready to download.
Whats new?
- Bug fixes
Fixed bug in ASC function
Fixed bug in left$
Fixed bug with loading basic constants
Fixed bug with incorrect compile time errors when two return types are possible
Fixed bug when returning a value in a function with using EXIT FUNCTION
- New:
Commmand: 'HLT' to stop execution of code. Handy for debugging
Added REPLACE$ to replace a portion of a string
Added SPLITITEM$: a 'split in place' function
Added Tally(): counts occurences of a char in a string
Added INSTRREV(): same as INSTR but then check from right to left
- Improved:
Performance improvement of about 50% on PSET
Compile time error checking on using the '+' operator on a mix between string and number
Implemented new way to load string and float literals, reducing prg size
Docs and download:
