nxtbasic : this loop runs automatically
funkheld
Post by funkheld »
hello, good day.
why does the loop automatically with gosub and sub ?
thanks.
greetings
SCREEN 128
StartEdit:
Loop:
Key$=GET
if Key$="D" then g = 129 : test()
Goto loop
end
sub test()
print "HALLO"
end sub
SCREEN 128
StartEdit:
Loop:
Key$=GET
if Key$="D" then g = 129 : gosub test
Goto loop
end
test:
print "HALLO"
return
it is ok without g = 129
SCREEN 128
StartEdit:
Loop:
Key$=GET
if Key$="D" then gosub test
Goto loop
end
test:
print "HALLO"
return
unartic
Re: nxtbasic : this loop runs automatically
Post by unartic »
It's a bug :-) It will be fixed with the next version of nxtBasic.
To workarround the bug, you can avoid putting commands on the same line as the IF-statement. So This will work:
SCREEN 128
StartEdit:
Loop:
Key$=GET
if Key$="D" then
end if
Goto loop
end
test:
print "HALLO"
return
funkheld
Post by funkheld »
hello, thanks for the help.
can you please remove this in screen 128 as well?
greetings
unartic
Post by unartic »
It's only visible when the bitmap layer is visible (screen 128). So yes, it will be gone soon :-)
