New demo uploaded: 3d wire frame animated spaceship
Johan Kårlin
Post by Johan Kårlin »
I remember doing this on the Amiga a long time ago. I had great help by the book "Atari ST 3D Graphichs Programming" (https://archive.org/details/Atari_ST-3D_Graphics_Programming/mode/2up). Of course, the programming examples are in 68000 assembler but there are also lengthy explanations of concepts and methods. If you are familiar with linear algebra, it really helps. When it comes to hidden line removal, a method that is discussed in the book is to calculate the normal vector of each plane (polygon). If the vector points towards the viewer, the plane is visible, if it points away from the viewer, the plane is hidden. The limitation is that this only works on convex bodies. (On concave bodies planes can be partially visible.) If you ever wondered why all ships in Elite are convex bodies I bet it is because this method is used : ). Another method is to simply sort the planes and then draw the furthest plane first and the closest last. It works well on for example mathematically rendered 3D landscapes where it makes sense of talking of the planes as positioned in a specific order. If I take a guess, this is the method the game "Virus" used.
Yeah the surface normal method is what I experimented with in my Python prototype shown above. It works fairly well and is quite cheap to do however it's not entirely accurate in the simplified version that I came up with.  I only check of the Z component is negative or positive and it works "most of the time" but fails for some polygons that are perspective projected.  I think it's acceptable though at least for a first solution!
As I'm only drawing lines not full surfaces the painter algorithm (back-to-front drawing) can't be used I think.
New version available, here we go,  hidden line removal based on that simple surface normal discussed above:
Adding more ships to the program and making a slide show of them is currently not possible due to programming language limitations of Prog8, unfortunately (everything has to be statically allocated)
SerErris
Post by SerErris »
Actually there was some recent and monumental work on documenting the original assembler of the BBC ELITE. The great stuff is, the BBC computer had a 6502 as well and all the MATH code and all the graphics code could be reused simply.
Obviously the draw routines need rework (e.g. the screen setup and output) and the sound as well. But if you ignore sound for now, and adapt the draw routines for the Vera, it should be possible to get the start screen working - e.g. your spinning ship with line removal ?
This is two masterpieces .. the longer I look at the Elite Source code ... wow ... and those guys were still in school or university at that time. And the comments is another masterpiece. I never have seen a better commented source code with actual explanations on how the engine worked. That includes all the math routines, how the backface culling works and alot of that stuff. It also completely explains the main game loop, how it works and so you can learn a lot by reading this.
The commenting has been done by Mark Moxon (of cause with a lot of help by others).
https://raw.githubusercontent.com/markmoxon/elite-beebasm/master/sources/elite-source.asm
This is the original definition of a MK3 btw:
\       Name: SHIP5
\       Type: Variable
\   Category: Drawing ships
\    Summary: Ship blueprint for a Cobra Mk III
.SHIP5
 EQUB 3                 \ Max. canisters on demise = 3
 EQUW 95 * 95           \ Targetable area          = 95 * 95
 EQUB &BC               \ Edges data offset (low)  = &00BC
 EQUB &54               \ Faces data offset (low)  = &0154
 EQUB 153               \ Max. edge count          = (153 - 1) / 4 = 38
 EQUB 84                \ Gun vertex               = 84 / 4 = 21
 EQUB 42                \ Explosion count          = 9, as (4 * n) + 6 = 42
 EQUB 168               \ Number of vertices       = 168 / 6 = 28
 EQUB 38                \ Number of edges          = 38
 EQUW 0                 \ Bounty                   = 0
 EQUB 52                \ Number of faces          = 52 / 4 = 13
 EQUB 50                \ Visibility distance      = 50
 EQUB 150               \ Max. energy              = 150
 EQUB 28                \ Max. speed               = 28
 EQUB &00               \ Edges data offset (high) = &00BC
 EQUB &01               \ Faces data offset (high) = &0154
 EQUB 1                 \ Normals are scaled by    = 2^1 = 2
 EQUB %00010011         \ Laser power              = 2
                        \ Missiles                 = 3
\VERTEX    x,    y,    z, face1, face2, face3, face4, visibility
 VERTEX   32,    0,   76,    15,     15,   15,    15,         31    \ Vertex 0
 VERTEX  -32,    0,   76,    15,     15,   15,    15,         31    \ Vertex 1
 VERTEX    0,   26,   24,    15,     15,   15,    15,         31    \ Vertex 2
 VERTEX -120,   -3,   -8,     3,      7,   10,    10,         31    \ Vertex 3
 VERTEX  120,   -3,   -8,     4,      8,   12,    12,         31    \ Vertex 4
 VERTEX  -88,   16,  -40,    15,     15,   15,    15,         31    \ Vertex 5
 VERTEX   88,   16,  -40,    15,     15,   15,    15,         31    \ Vertex 6
 VERTEX  128,   -8,  -40,     8,      9,   12,    12,         31    \ Vertex 7
 VERTEX -128,   -8,  -40,     7,      9,   10,    10,         31    \ Vertex 8
 VERTEX    0,   26,  -40,     5,      6,    9,     9,         31    \ Vertex 9
 VERTEX  -32,  -24,  -40,     9,     10,   11,    11,         31    \ Vertex 10
 VERTEX   32,  -24,  -40,     9,     11,   12,    12,         31    \ Vertex 11
 VERTEX  -36,    8,  -40,     9,      9,    9,     9,         20    \ Vertex 12
 VERTEX   -8,   12,  -40,     9,      9,    9,     9,         20    \ Vertex 13
 VERTEX    8,   12,  -40,     9,      9,    9,     9,         20    \ Vertex 14
 VERTEX   36,    8,  -40,     9,      9,    9,     9,         20    \ Vertex 15
 VERTEX   36,  -12,  -40,     9,      9,    9,     9,         20    \ Vertex 16
 VERTEX    8,  -16,  -40,     9,      9,    9,     9,         20    \ Vertex 17
 VERTEX   -8,  -16,  -40,     9,      9,    9,     9,         20    \ Vertex 18
 VERTEX  -36,  -12,  -40,     9,      9,    9,     9,         20    \ Vertex 19
 VERTEX    0,    0,   76,     0,     11,   11,    11,          6    \ Vertex 20
 VERTEX    0,    0,   90,     0,     11,   11,    11,         31    \ Vertex 21
 VERTEX  -80,   -6,  -40,     9,      9,    9,     9,          8    \ Vertex 22
 VERTEX  -80,    6,  -40,     9,      9,    9,     9,          8    \ Vertex 23
 VERTEX  -88,    0,  -40,     9,      9,    9,     9,          6    \ Vertex 24
 VERTEX   80,    6,  -40,     9,      9,    9,     9,          8    \ Vertex 25
 VERTEX   88,    0,  -40,     9,      9,    9,     9,          6    \ Vertex 26
 VERTEX   80,   -6,  -40,     9,      9,    9,     9,          8    \ Vertex 27
\EDGE vertex1, vertex2, face1, face2, visibility
 EDGE       0,       1,     0,    11,         31    \ Edge 0
 EDGE       0,       4,     4,    12,         31    \ Edge 1
 EDGE       1,       3,     3,    10,         31    \ Edge 2
 EDGE       3,       8,     7,    10,         31    \ Edge 3
 EDGE       4,       7,     8,    12,         31    \ Edge 4
 EDGE       6,       7,     8,     9,         31    \ Edge 5
 EDGE       6,       9,     6,     9,         31    \ Edge 6
 EDGE       5,       9,     5,     9,         31    \ Edge 7
 EDGE       5,       8,     7,     9,         31    \ Edge 8
 EDGE       2,       5,     1,     5,         31    \ Edge 9
 EDGE       2,       6,     2,     6,         31    \ Edge 10
 EDGE       3,       5,     3,     7,         31    \ Edge 11
 EDGE       4,       6,     4,     8,         31    \ Edge 12
 EDGE       1,       2,     0,     1,         31    \ Edge 13
 EDGE       0,       2,     0,     2,         31    \ Edge 14
 EDGE       8,      10,     9,    10,         31    \ Edge 15
 EDGE      10,      11,     9,    11,         31    \ Edge 16
 EDGE       7,      11,     9,    12,         31    \ Edge 17
 EDGE       1,      10,    10,    11,         31    \ Edge 18
 EDGE       0,      11,    11,    12,         31    \ Edge 19
 EDGE       1,       5,     1,     3,         29    \ Edge 20
 EDGE       0,       6,     2,     4,         29    \ Edge 21
 EDGE      20,      21,     0,    11,          6    \ Edge 22
 EDGE      12,      13,     9,     9,         20    \ Edge 23
 EDGE      18,      19,     9,     9,         20    \ Edge 24
 EDGE      14,      15,     9,     9,         20    \ Edge 25
 EDGE      16,      17,     9,     9,         20    \ Edge 26
 EDGE      15,      16,     9,     9,         19    \ Edge 27
 EDGE      14,      17,     9,     9,         17    \ Edge 28
 EDGE      13,      18,     9,     9,         19    \ Edge 29
 EDGE      12,      19,     9,     9,         19    \ Edge 30
 EDGE       2,       9,     5,     6,         30    \ Edge 31
 EDGE      22,      24,     9,     9,          6    \ Edge 32
 EDGE      23,      24,     9,     9,          6    \ Edge 33
 EDGE      22,      23,     9,     9,          8    \ Edge 34
 EDGE      25,      26,     9,     9,          6    \ Edge 35
 EDGE      26,      27,     9,     9,          6    \ Edge 36
 EDGE      25,      27,     9,     9,          8    \ Edge 37
\FACE normal_x, normal_y, normal_z, visibility
 FACE        0,       62,       31,         31    \ Face 0
 FACE      -18,       55,       16,         31    \ Face 1
 FACE       18,       55,       16,         31    \ Face 2
 FACE      -16,       52,       14,         31    \ Face 3
 FACE       16,       52,       14,         31    \ Face 4
 FACE      -14,       47,        0,         31    \ Face 5
 FACE       14,       47,        0,         31    \ Face 6
 FACE      -61,      102,        0,         31    \ Face 7
 FACE       61,      102,        0,         31    \ Face 8
 FACE        0,        0,      -80,         31    \ Face 9
 FACE       -7,      -42,        9,         31    \ Face 10
 FACE        0,      -30,        6,         31    \ Face 11
 FACE        7,      -42,        9,         31    \ Face 12
SerErris
Post by SerErris »
This is what Ian Bell and David Braben created (explained by Mark)
\       Name: LL9 (Part 5 of 11)
\       Type: Subroutine
\    Summary: Draw ship: Calculate the visibility of each of the ship's faces
\ Deep dive: Back-face culling
\ One of the reasons that Elite's 3D wireframe ships look so good is because
\ you can't see through them - they look genuinely solid. This is down to a
\ process called "back-face culling", a mathematical process that works out
\ which faces of the ship are visible to the viewer and which ones aren't. It
\ then discards (or "culls") any faces that aren't visible and only draws those
\ that we can actually see. This prevents the wireframes from being see-through,
\ and this gives the ships a real sense of solidity.
\ The main principle behind back-face culling is the dot product. This simple
\ mathematical operation takes two vectors and produces a scalar value that is
\ in essence a kind of mathematical application of one vector to the other, of
\ taking the "essence" of one vector and applying it to another. For the
\ purposes of back-face culling in Elite, we use the dot product in two distinct
\ ways.
This is just the summary, In the source is following long and long discussion on the details of that.
@SerErris WOW thanks for this info I had not discovered the annotated source code yet, incredible
SerErris
Post by SerErris »
I am really considering now to port it to X16 ... It is still a huge endeavour ... but it is getting possible now.
AndyMt
Post by AndyMt »
Wow - that would be HUGE ?!
