MONOMANIA 1bpp Video Demo
18 July 2024 Update
MONOMANIA2.zip
(44.41 MiB) Downloaded 56 times
3 new animation files (BADAPPLE.15FPS.A, WILLIE4.A, WILLIE5.A) these files REPLACE(BADAPPLE.13FPS,A, WILLIE.A & WILLIE2.A) plus the new .PRG, BAS & New assembly source. The other .A files from the Google drive download remain unchanged and are still required.
This update
1. Eliminates all screen tearing by using two graphics buffers. The graphics buffer base address is changed during VBLANK. Frame update is done to off screen buffer 2. Detects ROM version. Activates Fast serial mode if r47 or higher. This allows a constant 15 fps, HOSTFS & Hardware 3. Unfortunately, will run a bit more than 1 fps SLOWER on Hardware if ROM is pre r47. (Tested on r45). (app 12 fps)
The other animation files from the Google Drive file are still required.
HERE IT IS:
https://drive.google.com/file/d/1fLBm7I ... sp=sharing
This was formerly just 1bppdemo (1 bpp Video Demo). I gave it an overly important name :D and a flashy splash screen :roll: .
OLD CODE HERE
MONOMANIA.zip
(15.07 KiB) Downloaded 168 times
This still requires you to download the Google drive download below for the animation frame files. They are collectively to big to post on the forum. The zip is a bit over 100 mb's. The files you need from the below zip have an .A extension.
I will be posting a Youtube video of this running on hardware. I'm transcoding the video now.
Running on HARDWARE:
The video algorithm has been tested on HOSTFS, SD-Card Emulated & Hardware. On HOSTFS it's capable of about 22 fps.
On SD-Card - Emulated I'm a bit short of 10 fps. On Hardware it does better. 13.15 fps on one of my machines, 13.44 on the other.
FWIW The lower frame rate is on DEV0056 running r45. The Higher on PR0007 running r47.
It detects which file system it's on. On HOSTFS it Throttles to 13.2 fps deliberately to emulate hardware performance. It can't tell the difference between emulated SD-Card and HARDWARE SD-Card. On SD-Card it just goes as fast as possible.
File is to Big to include here due to multiple frame animation files. It's posted
on my Google Drive. https://drive.google.com/file/d/1fLBm7I ... sp=sharing
SPLASH SCREEN
MENU SCREENS
An ANIMATION STILL
HERE IT IS:
Re: MONOMANIA 1bpp Video Demo
ahenry3068 wrote: Wed May 15, 2024 7:52 amBUMP
Did you hit a wall? :D
Edmond D wrote: Wed May 15, 2024 3:38 pm
Yeah, we need the bump,
Gotta have that bump...
Do the bump-de-bump.
do the bump-de-bump.
mortarm wrote: Wed May 22, 2024 4:04 am Yeah, we need the bump,
You make it sound like he is banging his head against the wall. :D
I mean, if the thump fits....
Edmond D wrote: Wed May 22, 2024 2:26 pm
I will occasionally feel like doing this. Particularly when I'm drawing a blank on some bug in my code.
But as I value my walls I rarely follow through........... :D
I'd be interested in how the animation itself was created.
mortarm wrote: Sun May 26, 2024 8:25 pm I'd be interested in how the animation itself was created.
Import Video file into LiVes. --> Resize to 320 x 240 --> Adjust video Frame rate to 13.2
--> Do an encode of the video to any format whatsoever, We aren't going to use this video file,
When LiVes saves a Video file it also pulls all frames as individual PNG's. --> Save Clipset and exit LiVes.
Open GIMP. GIMP needs to have the Video Plugin and Jestin's VERA plugin installed.
Navigate to the LiVes folder holding the PNG files. Drag & Drop the first 1/2 dozen or dozen onto GIMP's Window
Wait for the import process to complete. (I was initially dropping ALL the frames on GIMP, took hours to load), turns out the Video Plugin doesn't need to have all of them loaded. Just enough to tell it where the source frames are. Might work with just the first two frames.
Go to the Video Plugin Menu and choose CONVERT frames. Choose the .BIN extension (which tells GIMP to use the VERA plugin).
When the VERA dialog presents choose VERA Bitmap. Uncheck "Use 2 Byte Header" --> Choose 1 bpp and Save Bitmap. Execute this command. You will also choose dithering at this point. I found "usually" Floyd-Steinberg - Reduce Color Bleeding is best. I have a copy of Steamboat Willie undithered and With this Dithering to illustrate that point. The SMOKE video (undithered) is actually dithered with this the Dithered version uses regular Floyd-Steinberg dithering.
LiVes uses ffmpeg and is Fast. But if I used ffmpeg to convert directly to 1 bpp the frames had the jaggie's. VERA plugin produced better frames, However, GIMP and the VERA Plugin are much slower than ffmpeg. This step can take a couple hours to complete.
Once all the frames are saved. I have a short QB64 program I wrote to concatenate them into a single file. My Video assembly routine has to be told explicitly how many frames to read so I had to keep track of them at this point.
TADA............. Video file created.
Interesting, but I think I was more interested in how the image morphing was done, or was this a converted video as well?
mortarm wrote: Thu May 30, 2024 3:31 am Interesting, but I think I was more interested in how the image morphing was done, or was this a converted video as well?
They are all converted videos.
