Which program can you use to convert float into 5 bytes for ASM?
mgkaiser
Re: Which program can you use to convert float into 5 bytes for ASM?
Post by mgkaiser »
Is there a way to write an assembler macro that takes a float constant and a name and emits "name .byte $00 $00 $00 $00 $00" where "name" is the name specified and the bytes are the float constant?
mgkaiser
Post by mgkaiser »
Or even better, bake into one of the 6502 assembler a datatype called ".float" into which you put a float constant and it emits 5 bytes?
PaulForgey
Post by PaulForgey »
Mine has .df that does just that.
mgkaiser
Post by mgkaiser »
PaulForgey wrote: Wed May 08, 2024 8:15 pm Mine has .df that does just that.
Which assembler is yours? Sounds like it might become mine too....
PaulForgey
It’s my own project, github.com/PaulForgey/xasm
It’s very picky about petscii source, so be sure you are either natively on the system (I developed it on hardware) or converting your source files.
