Hi good afternoon.
how can you use basload in a bank?
I would like to put my program for basload in bank 5 please.
then start with EXEC $a000.5.
how does that work please?
with basload :
10 BLOAD "FILE.BAS", 8, 1, $A000
20 POKE PEEK(781) + 256 * PEEK(782), 0
30 EXEC $A000, 1
40 NEW
Thanks.
greeting
basload in the bank ?
Re: basload in the bank ?
You can EXEC code in a Ram Bank (Cannot exceed a single bank (8192 bytes)) with a Non-Bank-aware routine like EXEC though.funkheld wrote: ↑Wed Mar 20, 2024 10:43 pm Hi good afternoon.
with basload :
30 EXEC $A000, 1
40 NEW
Thanks.
greeting
EXEC isn't going to work with BASLOAD code. It works as if you were typing the commands (including line numbers) at the immediate prompt.
Thanks for the info.
As always, I wanted to create the basic without a line number and then put it in the bank.
Is there somehow a transition bat to carry out the basload and then use a routine to push the data over to the bank.
It should only be one command overall.
Thanks.
greeting
Thanks.
greeting
Such a thing does not exist. BASLOAD tokenizes the code as it converts it to memory. EXEC operates on untokenized text. !!funkheld wrote: ↑Thu Mar 21, 2024 7:43 am Thanks for the info.
Thanks.
greeting
You would have to write such code yourself.
how can you call up the tokenizes code in the bank?
tanks greeting
tanks greeting
