Hi good afternoon.
I can't get through to the char and color yet.
How do the values combine with color , background-color, char without background-color etc.
Where can you read this please?
cx16.vpoke(1,$b000,1)
cx16.vpoke(1,$b000+1,1*16+2) ?????
Thanks.
greeting
char and color ....x16
- char-1.jpg (3.07 KiB) Viewed 1075 times
Re: char and color ....x16
There's 2 1bpp modes... from playing around with vpoke yesterday, the kernal mode used 1-bpp- 16 color
https://github.com/X16Community/x16-doc ... -text-mode
Tile mode 1 bpp (16 color text mode)
T256C should be set to 0.
MAP_BASE points to a tile map containing tile map entries, which are 2 bytes each:
Offset Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0
0 Character index
1 Background color Foreground color
So setting something like $10 for color in this mode would make the character inversed -> transparent on white background
If its the other mode -
Tile mode 1 bpp (256 color text mode)
T256C should be set to 1.
0 Character index
1 Foreground color
then $10 would set the foreground color to 16...
https://github.com/X16Community/x16-doc ... alette.png
which is black ....
so try setting the color code to $10 ( or 16) and see if you get black on transparent or transparent on white... Then you can tell which mode the text is in and what colors are available?
0 Character index
0 Character index
1 Foreground color
which is black ....
hello thanks for color-info and kacheln.
I will ask more questions please.
I don't really understand the tiles yet.
what exactly are tiles/kacheln?
are tiles/kacheln chars?
Where are the tiles made and stored please?
How are the tiles written on the screen?
thanks
greeting
thanks
greeting
tiles are 8 pixel by 8 pixel (well, by default - the VERA can do tilemaps 8x8,8x16x16x8,or16x16) images at the appropriate bitdepth... The text mode for both BASIC and the prog8 library you were using uses 8x8 1bpp (1 bit per pixel) graphics.
So at $TILE_BASE_ADDRESS, these are stored 1 after the other .. in binary it would look something like this -
00000000 ; +0, tile 0 -> blank
00000000
00000000
00000000
00000000
00000000
00000000
00000000
00000000 ; +8, tile 1 -> A
00011000
00100100
01000010
01111110
01000010
01000010
00000000
every 8 bytes -> 1 tile .
that is how the text modes use the tiles, but one could use them for any 8x8 bit of graphics... as an example, I would highly recommend checking out the youtube videos on PETSCII robots, which utilized the tile set to do all the drawing on the PET and a few other versions.
Other examples of this type of graphics scheme would be on the NES - the CHAR ROM contained 2 sets of 256 tiles the video chip could use for graphics...
in the 1bpp tile modes, only 256 tiles can be addressed, in the 2bpp,4bpp,8bpp ( 4 color, 16 color, 256 color ) tile modes, the 2bytes in the MAP data are defined differently -
0 Tile index (7:0)
1 Palette offset V-flip H-flip Tile index (9:8)
allowing up to 1024 different tiles and ability to flip them vertically or horizontally.
KERNAL puts the tile set here - $1:F000-$1:F7FF Charset
https://github.com/X16Community/x16-doc ... ace-layout
I tend to create tiles using a text editor, using binary or hex constants..
IE - in my assembly code might use this for 1bpp
.byte %00000000
.byte %00011000
.byte %00100100
.byte %01000010
.byte %01111110
.byte %01000010
.byte %01000010
.byte %00000000
But that would be the same as this string of HEX values -
.byte $00,$18,$24,$42,$7E,$42,$42,$00
By using a tiled layer mode, TILEBASE points to where tile #0 would start in VRAM, and then in the MAP you use the tile indexes.
IE - the charset the kernal uses has 'A' as tile #1, so to write an A onto the screen somewhere requires writing a 1.. 'F' is tile #6, etc.. and you would write those to the address corresponding with the row and column in the map.
if you wanted to place a 'tile' somewhere randomly on the screen... say at (137,53), then you would need to use a SPRITE or use a BITMAP mode layer and copy the pixels there yourself. ( Copying pixels in this way is often called 'blitting', in case you are trying to find more info on that technique)... BITMAP layers can be 1,2,4,or 8 bpp , SPRITES are limited to being 4 or 8bpp - you either have 16 color sprite or 256 color sprite ...
For a game, especially something trying to look like say an NES or SNES style game, layer0 might be configured to use a 2bpp or 4bpp tile mode.. with the map data and tiledata put somewhere in VRAM where there's room..
That would be for the background / level itself..
Then sprites between layer0 and layer1 for enemies, power ups, etc..
And maybe leave layer1 as text mode, so that you can write HUD or other text as an overlay.
You always ask where these things are stored... but the VERA is highly configurable, so unless you are using a particular defined mode, like say the way BASIC / KERNAL sets things up, or a particular programming library, the locations in VRAM are up to you, as well as which layers are enabled/disabled and the other assorted features, like switching the display from 640x480 to 320x240 or 160x120 or 256x192 or various points in-between with the scale registers ..
00000000
00000000
00000000
00000000
00000000
00000000
00000000
00011000
00100100
01000010
01111110
01000010
01000010
00000000
0 Tile index (7:0)
.byte %00000000
.byte %00011000
.byte %00100100
.byte %01000010
.byte %01111110
.byte %01000010
.byte %01000010
.byte %00000000
Hello, here is my example.
kachel 0 is : x=10 , y=50
txt.plot(10,50)
txt.print("@")
txt.color(col)
tiles/kacheln are chars?
I used tile/kachel 0 here in the example.
Can you please put the tiles at your own address?
thanks
thanks
greeting
txt.plot(10,50)
txt.print("@")
txt.color(col)
thanks
const uword VERA_CHARSET = $f000 ; $1f000
sub makechar() {
ubyte b
cx16.vaddr_autoincr(1, VERA_CHARSET, 0, 1)
b=255
cx16.VERA_DATA0 = b
b=129
cx16.VERA_DATA0 = b
b=129
cx16.VERA_DATA0 = b
b=129
cx16.VERA_DATA0 = b
b=129
cx16.VERA_DATA0 = b
b=129
cx16.VERA_DATA0 = b
b=129
cx16.VERA_DATA0 = b
b=255
cx16.VERA_DATA0 = b
b=131
cx16.VERA_DATA0 = b
b=129
cx16.VERA_DATA0 = b
b=129
cx16.VERA_DATA0 = b
b=129
cx16.VERA_DATA0 = b
b=129
cx16.VERA_DATA0 = b
b=129
cx16.VERA_DATA0 = b
b=129
cx16.VERA_DATA0 = b
b=129
cx16.VERA_DATA0 = b
b=255
cx16.VERA_DATA0 = b
b=129
cx16.VERA_DATA0 = b
b=129
cx16.VERA_DATA0 = b
b=129
cx16.VERA_DATA0 = b
b=129
cx16.VERA_DATA0 = b
b=129
cx16.VERA_DATA0 = b
b=129
cx16.VERA_DATA0 = b
b=129
cx16.VERA_DATA0 = b
b=129
cx16.VERA_DATA0 = b
b=129
cx16.VERA_DATA0 = b
b=129
cx16.VERA_DATA0 = b
b=129
cx16.VERA_DATA0 = b
b=129
cx16.VERA_DATA0 = b
b=129
cx16.VERA_DATA0 = b
b=129
cx16.VERA_DATA0 = b
b=255
cx16.VERA_DATA0 = b
b=128+64+2+1
cx16.VERA_DATA0 = b
b=129
cx16.VERA_DATA0 = b
b=129
cx16.VERA_DATA0 = b
b=129
cx16.VERA_DATA0 = b
b=129
cx16.VERA_DATA0 = b
b=129
cx16.VERA_DATA0 = b
b=129
cx16.VERA_DATA0 = b
b=255
cx16.VERA_DATA0 = b
b=24
cx16.VERA_DATA0 = b
b=24
cx16.VERA_DATA0 = b
b=24
cx16.VERA_DATA0 = b
b=24
cx16.VERA_DATA0 = b
b=24
cx16.VERA_DATA0 = b
b=24
cx16.VERA_DATA0 = b
b=24
cx16.VERA_DATA0 = b
b=24
cx16.VERA_DATA0 = b
greeting
- kachel.jpg (15.38 KiB) Viewed 916 times
Hi good afternoon.
If I change tile 0 during the game, then all tiles 0 that were previously written change.
can you please change that?
Thanks.
greeting
sub keypress(ubyte key) {
when key {
'r' -> makechar()
't' -> makechar1()
sub makechar() {
ubyte b
b=255
cx16.VERA_DATA0 = b
b=129
cx16.VERA_DATA0 = b
b=129
cx16.VERA_DATA0 = b
b=129
cx16.VERA_DATA0 = b
b=129
cx16.VERA_DATA0 = b
b=129
cx16.VERA_DATA0 = b
b=129
cx16.VERA_DATA0 = b
b=255
cx16.VERA_DATA0 = b
sub makechar1() {
ubyte b
b=0
cx16.VERA_DATA0 = b
b=129
cx16.VERA_DATA0 = b
b=129
cx16.VERA_DATA0 = b
b=129
cx16.VERA_DATA0 = b
b=129
cx16.VERA_DATA0 = b
b=129
cx16.VERA_DATA0 = b
b=129
cx16.VERA_DATA0 = b
b=0
cx16.VERA_DATA0 = b
greeting
Sorry, that is intended behavior. All displays of tile 0 use the same data. If you wish to make a change, and only have it affect one place, then you must define a new tile (tile 1, tile 2, etc.) and place it in that location in the map where you wish to see the change.
This does indeed mean that you should be careful to pay attention to your memory usage in how many tiles you define, especially if they are large tiles with many colors.
hello thanks for info.
greeting
greeting
