Hi good afternoon.
why does the data in the sprite demo start here in prog8:
const uword SPRITE_DATA_ADDR = $2000 ?
in the x16 kernal : $1:3000 - $1:afff
main {
; we choose arbitrary unused vram location for sprite data: $12000
const ubyte SPRITE_DATA_BANK = 1
const ubyte SPRITE_PALETTE_OFFSET_IDX = 16
Thanks.
greeting
prog8: const uword SPRITE_DATA_ADDR = $2000 ?
- sprite-data.jpg (36.11 KiB) Viewed 839 times
Re: prog8: const uword SPRITE_DATA_ADDR = $2000 ?
you can put the sprite data everywhere you like, as long as you also set the sprite data pointer to the correct values, and handle all sprite register manipulation yourself.
I don't know why that $13000 region is even mentioned tbh. Maybe for the two kernal routines that handle sprites? I've never used those.
That table explains how the Kernal configures the VERA's memory layout when you're using the Kernal's text mode and graphics/sprite routines.
If you're not using these Kernal functions, then you can manually configure the VERA's memory layout however you like, but it will be your program's responsibility to operate the VERA, instead of relying on Kernal functions.
danke für die info.
gruss
gruss
