BASIC high memory limit?
PaulForgey
Post by PaulForgey »
Is it possible to tell the BASIC interpreter to use a maximum high address for variable storage? (like the Applesoft HIMEM:) I'd like to unit test some assembly modules that use this same area of memory for its own storage and not clash
Re: BASIC high memory limit?
Yes, there's a way to set MEMTOP... I just don't remember how to do it. Let me check with @MooingLemur, who would know the answer to that one.
10 POKE$30F,1:SYS$FF99 20 Y=$8C:X=$00 30 POKE$30D,X:POKE$30E,Y:POKE$30F,0:SYS$FF99 40 CLR
So the way this works: the MEMTOP function in KERNAL serves to both read and set the top of BASIC, as well as to set the number of available RAM banks. (64 or 256, depending on whether you have 512K or 2MB of extended RAM.)
Calling MEMTOP with the Carry flag set reads the values. Calling MEMTOP with the Carry flag clear sets the values.
So the process is to:
  1. Read the values
  2. Alter the top of BASIC (X and Y)
  3. Write them back
To see if this is working, you can add 2 more lines:
0 PRINT FRE(0) 50 PRINT FRE(0)
Also... lay out your memory the way you want to... but you should know, if you don't already, that the area from $0400 to $07FF is unused by the system (and is not needed for the memory map of the text screen like it was on the C64, because that's stored in VERA's own screen RAM), so could be used for up to 1KB of assembly code, binary variables, etc.
PaulForgey
Thanks, in the time since I posted I found MEMTOP, but found creating a new variable and querying POINTER on it still shows an address above, yet fre(0) does reflect the new memtop setting. Even if I new NEW or CLR first.
Setting memtop=$7fff, if that matters.
PaulForgey
Found my issue: using load "file",8,1 to an address above memtop leaves things in a very strange state. If I load my binaries and then set memtop, I appear OK
PaulForgey
..and of course it would! I was stupidly unaware using ,1 still messes with BASICs internal pointers. So the variable space is left above the end of the loading, thus loading above memtop would do strange things.
PaulForgey wrote: Tue Mar 12, 2024 8:56 pm ..and of course it would! I was stupidly unaware using ,1 still messes with BASICs internal pointers. So the variable space is left above the end of the loading, thus loading above memtop would do strange things.
It's ok to use BLOAD above memtop. I usually use BLOAD if I'm loading binary assets.
Yeah, you want to use BLOAD to load your ML routines. When you assemble them, assemble them as .BIN files without the 2 byte address pointer.
