Hi good afternoon.
I'm playing with the Prog8.
Where pleace can you find out how many import libraries there are for the
x16 and what is in the libraries or what I can call from it
for my program?
Thanks.
greeting
%import textio
%import diskio
%import math
%import syslib
%import palette
%import zsmkit
%import sprites
%import joystick
%import SpritePathTables
%zeropage basicsafe
Librarys for Prog8
Re: Librarys for Prog8
Hullo! Yeah here is some documentation of part of the libraries: https://prog8.readthedocs.io/en/latest/libraries.html
The rest is , shall we say, "Use the source, Luke" https://github.com/irmen/prog8/tree/mas ... s/prog8lib
I also advise to study the dozens of examples https://github.com/irmen/prog8/tree/master/examples
Thanks for the help.
I've made some progress now.
Thanks.
greeting
Thanks.
greeting
If you feel so inclined, there's a small but active sub-community using and discussing prog8 on the Commander X16 Discord and helping each other out. It's more interactive than this forum, if that suits you.
How do I get there on the internet please?
Thanks.
greeting
Thanks.
greeting
There's a link to the discord server on the front page of this forum https://cx16forum.com/
and the prog8 channel in there is called #prog8-dev
Hi good afternoon.
what is the difference please:
graphics and gfx2 on pro8?
Thanks.
greeting
Thanks.
greeting
gfx2 has more features (like flood fill) and has different screen modes. But it only works on the commander X16.
graphics is also available on the Commodore-64
hello, thanks for info.
greeting
greeting
