What PC case are you using?
debug_ninja
Re: What PC case are you using?
Post by debug_ninja »
voidstar wrote: Mon Jan 22, 2024 6:24 am
debug_ninja wrote: Mon Jan 22, 2024 3:26 am I am tempted to buy something like this but I’m unsure if it will be too tight a fit. I like the handle and 60 isn’t too bad
I got one of these, just as temporary for now. As an mATX, it is not a tight fit for the X16 board. But keep in mind for that price, it doesn't come with any fans or power supply - not that you need those here, but it makes less of a good deal.
Attached is a photo to give an idea of the space. One nice thing is I plug pins into the up-front USB port to draw 5V right off the X16 board (5V clearly marked near the FP and I2C group of pins). So that 5V can charge a phone or some IEC disk drive emulator, etc. Note there is no switch upfront for RESET or drive activity light - that hasn't really been a big deal, with the side glass window I can see the onboard activity LED just fine, and CTRL+ALT+DEL from the keyboard does a reset reliably enough.
The "fine grill" stuff that comes with that case is just "sticker on" (not magnetic, or at least I don't think it is) so I didn't use it. That left space to pass the SD extender thru.
With the holes top and bottom, it might be easier to cut out a space for a side-insert cartridge someday.
Thanks for posting this picture, I ended up ordering the same case and as soon as I get it I’ll post my picture :)
debug_ninja
General - CX16 Re: What PC case are you using?
I finally got mine put all together and even made a case badge :)
voidstar
Post by voidstar »
Nice badge!
Maybe a soundbar could be fit inside for some self contained speakers?
debug_ninja
voidstar wrote: Sat Feb 03, 2024 8:49 am Nice badge!
I actually did explore adding an internal speaker :p
steev
Post by steev »
I found a really nice low profile MicroATX case that uses a FlexATX power supply.
It's a SilverStone MILO 11. I would have preferred a white case but this will do.
I found it on Amazon & Newegg for around $75 without the power supply.
2024-02-10 08.43.10 sm.jpg (167.2 KiB) Viewed 3166 times
2024-02-10 08.42.16 sm.jpg (312.41 KiB) Viewed 3166 times
It's nice and compact measuring 33cm wide x 11cm tall x 28.5cm deep.
I did have to remove the two USB 3 connectors(they were easy to unscrew) as the cables were really bulky. It does leave small empty holes in the front but it's minimal.
Instead of the Flex ATX power supply, I'm going to just keep using the power brick that came with the Commander X16, and place a plate over the power supply hole and mount the connector to that.
The only thing it needs is an IO shield for the back, (does anyone make them?)
and a large Command x16 branding case back to cover the Silverstone logo. (does anyone make those?)
Dropping a note here that the Lazer3D case is taking pre-orders again.
steev wrote: Sun Feb 18, 2024 3:39 am I found a really nice low profile MicroATX case that uses a FlexATX power supply.
MooDawg is offering 3-D printed I/O shields for the X16 now.
steev
Post by steev »
ahenry3068 wrote: Fri Mar 01, 2024 12:16 pm MooDawg is offering 3-D printed I/O shields for the X16 now.
Who is that?
steev wrote: Sat Mar 02, 2024 2:32 pm
Who is that?
He's over on Discord more than he is here. He's also the developer doing DreamTracker. viewtopic.php?t=6803
Merri
Post by Merri »
The Checkmate A1500 Plus case was mentioned in this thread, so since that is what I decided to get here is how it looks like!
The ATX screw holes were a bit off, had to keep the screws loose before having all of them in place, and only once had all of them in place I could screw all of them in.
Getting the top lid back on was also a bit of an experimentation effort. Though once it is in place everything is fine!
Board in case from above
Case front with no lid
Case and board from back with lid inserted
Completed setup with old LCD monitor, speakers, Classic SNES gamepad, keyboard and mouse
So far I haven't had the interest for all the rest of the chips, but maybe I could order them to have the option to avoid any regrets in future :D
