I had not noticed that it actually saves to different addresses.
When looking at the VTUI library documentation https://github.com/jimmydansbo/vtuilib? ... -save_rect , my guess is that the vtui.save_rect prototype would be something like this:
vtui.save_rect(memtype, bank, address, width, height) where
memtype: $80 for video memory, $00 for system memory
bank: VERA bank if memtype=$80
address: Address in memory to write screen content to
width, height: size of area to save.
So it seems like store_logo first save the logo to address $10000 in VRAM, then it saves the logo to address $10100 in VRAM
store_where_logo_was saves the logo to $10010 and then to $10100 in VRAM.
As the area saved is 7x7 characters x2 for color information it uses 92 or $62 bytes of memory.
store_logo saves logo to address $10000 and store_where_logo_was saves logo to $10010 which would overwrite the logo saved by store_logo.
VTUI Library
- JimmyDansbo
- Contact:
Re: VTUI Library
Visit my Github repo
Re: VTUI Library
Hello, with which acme was this asm compiled please?
I'm just having trouble with my ACME.
Thanks.
greeting
Thanks.
greeting
- JimmyDansbo
- Contact:
Re: VTUI Library
I suggest you use the latest version of Acme from here:
https://sourceforge.net/projects/acme-crossass/
- JimmyDansbo
- Contact:
Re: VTUI Library
I am happy to announce that I have released version 1.1 of the VTUI library.
It is only a few minor additions.
All images, downloads and links in top post are edited to correspond to version 1.1
For changes, see https://github.com/JimmyDansbo/VTUIlib/releases
As always, please let me know if you find any bugs or errors, or if you have questions or comments.
- JimmyDansbo
- Contact:
Re: VTUI Library
I am happy to announce that version 1.2 has been released.
Only return value of input_str has been changed
- JimmyDansbo
- Contact:
Re: VTUI Library
I thought I would try and write the first part of the VTUI demo in BASIC since now we have TILE, TDATA & TATTR functions in ROM.
It is not quite as fast as VTUI, but it does work.
To have it move the logo, do the following after the code has been pasted in:
* Reset the emulator (CTRL+R)
BUT ONLY IN LATEST ROM (NOT R46 OR OLDER)
10 DIM LD(7*7) 20 DIM LA(7*7) 30 DIM SD(7*7) 40 DIM SA(7*7) 45 CX=0:CY=0 50 FORY=0TO6:FORX=0TO6 60 LD((Y*7)+X)=TDATA(X,Y):LA((Y*7)+X)=TATTR(X,Y) 70 SD((Y*7)+X)=$20:SA((Y*7)+X)=$61 80 NEXT:NEXT 100 GET A$: IF A$="" THEN 100 110 IF ASC(A$)=29 THEN 1000 120 IF ASC(A$)=17 THEN 2000 130 IF ASC(A$)=157 THEN 3000 140 IF ASC(A$)=145 THEN 4000 145 IF ASC(A$)=27 THEN END 150 GOTO 100 999 REM GO RIGHT 1000 IFCX>(79-7)THEN100 1010 FOR Y=0TO6:FORX=0TO6 1020 TILE CX+X,CY+Y,SD((Y*7)+X),SA((Y*7)+X) 1030 NEXT:NEXT 1040 CX=CX+1 1050 FORY=0TO6:FORX=0TO6 1060 SD((Y*7)+X)=TDATA(CX+X,CY+Y):SA((Y*7)+X)=TATTR(CX+X,CY+Y) 1070 TILE CX+X,CY+Y,LD((Y*7)+X),LA((Y*7)+X) 1080 NEXT:NEXT 1090 GOTO 100 1999 REM GO DOWN 2000 IF CY>(59-7) THEN 100 2010 FOR Y=0TO6:FORX=0TO6 2020 TILE CX+X,CY+Y,SD((Y*7)+X),SA((Y*7)+X) 2030 NEXT:NEXT 2040 CY=CY+1 2050 FORY=0TO6:FORX=0TO6 2060 SD((Y*7)+X)=TDATA(CX+X,CY+Y):SA((Y*7)+X)=TATTR(CX+X,CY+Y) 2070 TILE CX+X,CY+Y,LD((Y*7)+X),LA((Y*7)+X) 2080 NEXT:NEXT 2090 GOTO 100 2999 REM GO LEFT 3000 IF CX=0 THEN 100 3010 FOR Y=0TO6:FORX=0TO6 3020 TILE CX+X,CY+Y,SD((Y*7)+X),SA((Y*7)+X) 3030 NEXT:NEXT 3040 CX=CX-1 3050 FORY=0TO6:FORX=0TO6 3060 SD((Y*7)+X)=TDATA(CX+X,CY+Y):SA((Y*7)+X)=TATTR(CX+X,CY+Y) 3070 TILE CX+X,CY+Y,LD((Y*7)+X),LA((Y*7)+X) 3080 NEXT:NEXT 3090 GOTO 100 3999 REM GO UP 4000 IF CY=0 THEN 100 4010 FOR Y=0TO6:FORX=0TO6 4020 TILE CX+X,CY+Y,SD((Y*7)+X),SA((Y*7)+X) 4030 NEXT:NEXT 4040 CY=CY-1 4050 FORY=0TO6:FORX=0TO6 4060 SD((Y*7)+X)=TDATA(CX+X,CY+Y):SA((Y*7)+X)=TATTR(CX+X,CY+Y) 4070 TILE CX+X,CY+Y,LD((Y*7)+X),LA((Y*7)+X) 4080 NEXT:NEXT 4090 GOTO 100Try It Now!
OLD RUN
MOVELOGO.BAS
- (1.54 KiB) Downloaded 421 times
