Confusion about using cache write to fill polygons
hstubbs3
Post by hstubbs3 »
The VERA FX tutorial and doc both indicate that the cache write is always to 4-byte aligned address...
And using it with the linear bitmap buffers, each line would always start at 4-byte aligned point..
Would be _nice_ to have more options for bitmap width, but anyways...
The polygon helper sets the initial x for addr1 for you, which is not guaranteed to be 4-byte aligned at all... so what's the expected / optimal strategy to use with the polygon helper when drawing arbitrary polygons using cache writes?
Is the doc wrong and the cache write isn't always 4-byte aligned? can you read the calculated addr1 back from the vera without causing some weird side effect??
