For a reference example, I came across the entropy example in the X16 ref docs, and decided to show what the X16 BASIC equivalent of that would look like. Maybe helps those not familiar with BASIC...
10 REM THROW A 6-SIDED DIE
20 SYS $FECF:REM JSR ENTROPY-GET
30 A=PEEK($030C):REM STORE REG .A RESULT
40 X=PEEK($030D):REM STORE REG .X RESULT
50 Y=PEEK($030E):REM STORE REG .Y RESULT
60 REM A = A XOR X
70 A=(A OR X) AND NOT (A AND X)
80 REM A = A XOR Y
90 A=(A OR Y) AND NOT (A AND Y)
100 AZ=A:REM STORE COPY OF A
110 REM A = A >> 4 (LSR, LOGICAL SHIFT RIGHT)
120 A=INT(A/16)
130 REM A = A XOR AZ
140 A=(A OR AZ) AND NOT (A AND AZ):REM A IS NOW 4-BIT
150 A=A AND $07:REM KNOCK OFF THE TOP BIT, NOW 3-BIT
160 IF A=0 GOTO 20:REM ZERO IS INVALID ROLL VALUE
170 IF A=7 GOTO 20:REM SEVEN IS INVALID ROLL VALUE
180 A=A OR $30:REM I.E. ASCII 48 + NUMERIC INDEX
REM DONE, NOW SHOW THE OUTPUT...
190 POKE $030C,A:REM SET REG .A TO OUTPUT VALUE
200 SYS $FFD2:REM JSR OUTPUT CHAR IN REG.A
210 RETURN
REM DO A LITTLE TEST CASE LOOP...
1000 FOR I = 1 TO 20
1010 GOSUB 10:PRINT "/";:PRINT CHR$(A);" ";
1020 NEXT I
ASM and BASIC sample comparison (and FN/XOR example)
- asm_and_basic.png (42.98 KiB) Viewed 3411 times
Re: ASM and BASIC sample comparison (and FN example)
Realized this is also a good example to show how to make use of the BASIC FN keyword. Especially as this BASIC doesn't have a XOR keyword
FN is fairly limited (single line only, cannot use ":" for multiple statement function, single argument only). The defined function name (XO in this sample, for XOR) seems to be separate from the XO variable (i.e. defining a FN doesn't consume a variable name, but the FN names have the same variable name restrictions {e.g. two letters}).
5 DEF FN XO(Z) = (A OR Z) AND NOT (A AND Z) 10 REM THROW A 6-SIDED DIE 20 SYS $FECF:REM JSR ENTROPY-GET 30 A=PEEK($030C):REM STORE REG .A RESULT 40 X=PEEK($030D):REM STORE REG .X RESULT 50 Y=PEEK($030E):REM STORE REG .Y RESULT 70 A=FN XO(X):REM A = A XOR X 90 A=FN XO(Y):REM A = A XOR Y 100 AZ=A:REM STORE COPY OF A 110 REM A = A >> 4 (LSR, LOGICAL SHIFT RIGHT) 120 A=INT(A/16) 130 REM A = A XOR AZ 140 A=FN XO(AZ):REM A IS NOW 4-BIT 150 A=A AND $07:REM KNOCK OFF THE TOP BIT, NOW 3-BIT 160 IF A=0 GOTO 20:REM ZERO IS INVALID ROLL VALUE 170 IF A=7 GOTO 20:REM SEVEN IS INVALID ROLL VALUE 180 A=A OR $30:REM I.E. ASCII 48 + NUMERIC INDEX 190 POKE $030C,A:REM SET REG .A TO OUTPUT VALUE 200 SYS $FFD2:REM JSR OUTPUT CHAR IN REG.A 210 RETURN 1000 FOR I = 1 TO 20 1010 GOSUB 5:PRINT "/";:PRINT CHR$(A);" "; 1020 NEXT I
- basic_entropy_fn_sample.png (14.66 KiB) Viewed 3406 times
