Using the "-m" argument of ld65 (part of cc65), I can get some size metrics of each of the compiled units of this Zork.
NOTE: I'm compiling without any optimization, since currently optimization is causing issues with cc65 on this particular set of code -- some branches end up attempted beyond 127 offset when optimization is enabled.
Here is a summary of the memory need per C module:
- zork1_memory_summary.png (16.91 KiB) Viewed 987 times
Zork tries to be "self sufficient" by having a lot of the Room and Object string descriptions as part of the build, rather than external files. Maybe this was a performance thing, as any disk access even in 1980 would have been slow (and noisy). There are 111 rooms and 80 objects. I considered just reducing the number of rooms (and objects), since even just being able to move between two rooms would be a nice proof-of-concept. But so far it's not that simple.
The parsing code itself is roughly 47K (to handle verbs and nouns; that's code and data).
Then the supporting code, to transition between rooms (which has special handling of objects and encounters), that's about 60K (which includes handling three "villain" encounters) -- plus about 57K of supporting DATA. The Room and Object data is compressed, and C code uses malloc/free when Uncompressing that data (so at least about 300 bytes of RAM needs to available to hold the uncompressed thing).
Then there is a RNG and TextCompression support routines, which altogether need about another 7K (combined with the C-standard library stuff that is also some byte code that needs to be compiled in).
The good news is this should be do-able even on a 256KB system (CODE+DATA totally to about 180KB). But I'm still not sure how to take advantage of BANKing here.
It seems I need a way to say "I want this specific function compiled for BANK n" (which means anytime I invoke that function, BANK n is activated right before the call -- and maintain a stack of BANK changes in case of nested calls).
The Room Descriptions is probably the largest const data structure, and I think it was right at about 7.5KB -- so a way to designate which BANK that gets stored on would help (and automatically switch to that BANK - and back - when using the data structure).
Still getting oriented on how this code is arranged...
Modules list:
compress.o: contains CompressText and DecompressText
CODE Offs=000000 Size=00075E Align=00001 Fill=0000 1886 bytes
RODATA Offs=000000 Size=0002C3 Align=00001 Fill=0000 707 bytes
DATA Offs=000000 Size=000006 Align=00001 Fill=0000
game.o: handles transition from one room to another
CODE Offs=00075E Size=00B81A Align=00001 Fill=0000 47,130 bytes
RODATA Offs=0002C3 Size=009DAD Align=00001 Fill=0000 40,365 bytes
BSS Offs=000000 Size=000058 Align=00001 Fill=0000
DATA Offs=000006 Size=000784 Align=00001 Fill=0000 1,924 bytes
mt.o: implements random number generator ("Mersenne Twist")
CODE Offs=00BF78 Size=000825 Align=00001 Fill=0000 2,085 bytes
BSS Offs=000058 Size=0004E4 Align=00001 Fill=0000 1,252 bytes
DATA Offs=00078A Size=000004 Align=00001 Fill=0000
parser.o: main() is here, handles the game parsing
malloc/free used when room descriptions Decompressed
CODE Offs=00C79D Size=007C13 Align=00001 Fill=0000 31,763 bytes
RODATA Offs=00A070 Size=000F53 Align=00001 Fill=0000 3,923 bytes
BSS Offs=00053C Size=000472 Align=00001 Fill=0000 1,138 bytes
DATA Offs=00078E Size=000008 Align=00001 Fill=0000
tables.o: room "scenery", room passages, object locations and rules,
verb to action, noun tables,
RODATA Offs=00AFC3 Size=001302 Align=00001 Fill=0000 4,865 bytes
DATA Offs=000796 Size=001CE3 Align=00001 Fill=0000 7,395 bytes
villains.o: handles a troll, thief, and cyclopes encounters
CODE Offs=0143B0 Size=00336E Align=00001 Fill=0000 13,166 bytes
RODATA Offs=00C2C5 Size=000B8F Align=00001 Fill=0000 2,959 bytes
DATA Offs=002479 Size=000018 Align=00001 Fill=0000
_data.o: compressed Room and Object descriptions
RODATA Offs=00CE54 Size=002E2F Align=00001 Fill=0000 11,823 bytes
DATA Offs=002491 Size=0001AC Align=00001 Fill=0000 428 bytes
..\lib\cx16.lib(_directerrno.o):
CODE Offs=01771E Size=000009 Align=00001 Fill=0000
..\lib\cx16.lib(_fdesc.o):
CODE Offs=017727 Size=00001D Align=00001 Fill=0000
..\lib\cx16.lib(_file.o):
DATA Offs=00263D Size=00001E Align=00001 Fill=0000
..\lib\cx16.lib(_fopen.o):
CODE Offs=017744 Size=00007B Align=00001 Fill=0000
BSS Offs=0009AE Size=000002 Align=00001 Fill=0000
..\lib\cx16.lib(_heap.o):
DATA Offs=00265B Size=00000A Align=00001 Fill=0000
ONCE Offs=000000 Size=000010 Align=00001 Fill=0000
..\lib\cx16.lib(_hextab.o):
RODATA Offs=00FC83 Size=000010 Align=00001 Fill=0000
..\lib\cx16.lib(_longminstr.o):
RODATA Offs=00FC93 Size=00000C Align=00001 Fill=0000
..\lib\cx16.lib(_mappederrno.o):
CODE Offs=0177BF Size=00000F Align=00001 Fill=0000
..\lib\cx16.lib(_oserror.o):
BSS Offs=0009B0 Size=000001 Align=00001 Fill=0000
..\lib\cx16.lib(_printf.o):
CODE Offs=0177CE Size=0003A5 Align=00001 Fill=0000 943 bytes
BSS Offs=0009B1 Size=00002B Align=00001 Fill=0000
DATA Offs=002665 Size=000003 Align=00001 Fill=0000
..\lib\cx16.lib(_seterrno.o):
CODE Offs=017B73 Size=000009 Align=00001 Fill=0000
..\lib\cx16.lib(add.o):
CODE Offs=017B7C Size=000018 Align=00001 Fill=0000
..\lib\cx16.lib(addeqsp.o):
CODE Offs=017B94 Size=000011 Align=00001 Fill=0000
..\lib\cx16.lib(addysp.o):
CODE Offs=017BA5 Size=00000E Align=00001 Fill=0000
..\lib\cx16.lib(aslax1.o):
CODE Offs=017BB3 Size=000008 Align=00001 Fill=0000
..\lib\cx16.lib(aslax2.o):
CODE Offs=017BBB Size=00000B Align=00001 Fill=0000
..\lib\cx16.lib(aslax3.o):
CODE Offs=017BC6 Size=00000E Align=00001 Fill=0000
..\lib\cx16.lib(aslax4.o):
CODE Offs=017BD4 Size=000011 Align=00001 Fill=0000
..\lib\cx16.lib(atexit.o):
CODE Offs=017BE5 Size=000037 Align=00001 Fill=0000
BSS Offs=0009DC Size=00000B Align=00001 Fill=0000
..\lib\cx16.lib(axlong.o):
CODE Offs=017C1C Size=00000D Align=00001 Fill=0000
..\lib\cx16.lib(bankramaddr.o):
BRAM01ADDR Offs=000000 Size=000002 Align=00001 Fill=0000
BRAM02ADDR Offs=000000 Size=000002 Align=00001 Fill=0000
BRAM03ADDR Offs=000000 Size=000002 Align=00001 Fill=0000
BRAM04ADDR Offs=000000 Size=000002 Align=00001 Fill=0000
BRAM05ADDR Offs=000000 Size=000002 Align=00001 Fill=0000
BRAM06ADDR Offs=000000 Size=000002 Align=00001 Fill=0000
BRAM07ADDR Offs=000000 Size=000002 Align=00001 Fill=0000
BRAM08ADDR Offs=000000 Size=000002 Align=00001 Fill=0000
BRAM09ADDR Offs=000000 Size=000002 Align=00001 Fill=0000
..\lib\cx16.lib(bneg.o):
CODE Offs=017C29 Size=00000E Align=00001 Fill=0000
..\lib\cx16.lib(call.o):
CODE Offs=017C37 Size=000007 Align=00001 Fill=0000
..\lib\cx16.lib(callmain.o):
CODE Offs=017C3E Size=000017 Align=00001 Fill=0000
DATA Offs=002668 Size=000004 Align=00001 Fill=0000
..\lib\cx16.lib(close.o):
CODE Offs=017C55 Size=000038 Align=00001 Fill=0000
..\lib\cx16.lib(condes.o):
CODE Offs=017C8D Size=00000C Align=00001 Fill=0000
DATA Offs=00266C Size=000025 Align=00001 Fill=0000
ONCE Offs=000010 Size=00000C Align=00001 Fill=0000
..\lib\cx16.lib(crt0.o):
STARTUP Offs=000000 Size=000021 Align=00001 Fill=0000
ONCE Offs=00001C Size=00001B Align=00001 Fill=0000
INIT Offs=000000 Size=000002 Align=00001 Fill=0000
..\lib\cx16.lib(ctype.o):
RODATA Offs=00FC9F Size=00008B Align=00001 Fill=0000
..\lib\cx16.lib(ctypemask.o):
CODE Offs=017C99 Size=00001E Align=00001 Fill=0000
..\lib\cx16.lib(decax1.o):
CODE Offs=017CB7 Size=000007 Align=00001 Fill=0000
..\lib\cx16.lib(decax4.o):
CODE Offs=017CBE Size=000007 Align=00001 Fill=0000
..\lib\cx16.lib(decaxy.o):
CODE Offs=017CC5 Size=000009 Align=00001 Fill=0000
..\lib\cx16.lib(decsp1.o):
CODE Offs=017CCE Size=000009 Align=00001 Fill=0000
..\lib\cx16.lib(decsp2.o):
CODE Offs=017CD7 Size=00000D Align=00001 Fill=0000
..\lib\cx16.lib(decsp4.o):
CODE Offs=017CE4 Size=00000D Align=00001 Fill=0000
..\lib\cx16.lib(decsp6.o):
CODE Offs=017CF1 Size=00000D Align=00001 Fill=0000
..\lib\cx16.lib(decsp8.o):
CODE Offs=017CFE Size=00000D Align=00001 Fill=0000
..\lib\cx16.lib(diskcmd.o):
CODE Offs=017D0B Size=0000C4 Align=00001 Fill=0000
BSS Offs=0009E7 Size=000017 Align=00001 Fill=0000
..\lib\cx16.lib(div.o):
CODE Offs=017DCF Size=000015 Align=00001 Fill=0000
..\lib\cx16.lib(divt.o):
CODE Offs=017DE4 Size=000015 Align=00001 Fill=0000
..\lib\cx16.lib(eq.o):
CODE Offs=017DF9 Size=00000A Align=00001 Fill=0000
..\lib\cx16.lib(errno.o):
BSS Offs=0009FE Size=000002 Align=00001 Fill=0000
..\lib\cx16.lib(exehdr.o):
EXEHDR Offs=000000 Size=00000C Align=00001 Fill=0000
..\lib\cx16.lib(fclose.o):
CODE Offs=017E03 Size=000022 Align=00001 Fill=0000
..\lib\cx16.lib(fgetc.o):
CODE Offs=017E25 Size=000084 Align=00001 Fill=0000
..\lib\cx16.lib(fgets.o):
CODE Offs=017EA9 Size=0000A8 Align=00001 Fill=0000
..\lib\cx16.lib(filedes.o):
CODE Offs=017F51 Size=00000E Align=00001 Fill=0000
DATA Offs=002691 Size=000010 Align=00001 Fill=0000
..\lib\cx16.lib(filename.o):
CODE Offs=017F5F Size=0000A0 Align=00001 Fill=0000
BSS Offs=000A00 Size=000003 Align=00001 Fill=0000
DATA Offs=0026A1 Size=000024 Align=00001 Fill=0000
..\lib\cx16.lib(filetype.o):
DATA Offs=0026C5 Size=000001 Align=00001 Fill=0000
..\lib\cx16.lib(filevars.o):
CODE Offs=017FFF Size=000007 Align=00001 Fill=0000
INIT Offs=000002 Size=000001 Align=00001 Fill=0000
ONCE Offs=000037 Size=00000E Align=00001 Fill=0000
..\lib\cx16.lib(fmisc.o):
CODE Offs=018006 Size=000044 Align=00001 Fill=0000
..\lib\cx16.lib(fopen.o):
CODE Offs=01804A Size=000018 Align=00001 Fill=0000
..\lib\cx16.lib(fputc.o):
CODE Offs=018062 Size=000054 Align=00001 Fill=0000
RODATA Offs=00FD2A Size=000002 Align=00001 Fill=0000
..\lib\cx16.lib(fputs.o):
CODE Offs=0180B6 Size=000041 Align=00001 Fill=0000
..\lib\cx16.lib(fread.o):
CODE Offs=0180F7 Size=0000D3 Align=00001 Fill=0000
BSS Offs=000A03 Size=000003 Align=00001 Fill=0000
..\lib\cx16.lib(free.o):
CODE Offs=0181CA Size=0001D3 Align=00001 Fill=0000
..\lib\cx16.lib(fwrite.o):
CODE Offs=01839D Size=00007B Align=00001 Fill=0000
BSS Offs=000A06 Size=000002 Align=00001 Fill=0000
..\lib\cx16.lib(ge.o):
CODE Offs=018418 Size=00000A Align=00001 Fill=0000
..\lib\cx16.lib(getchar.o):
CODE Offs=018422 Size=000009 Align=00001 Fill=0000
..\lib\cx16.lib(gettime.o):
CODE Offs=01842B Size=00004C Align=00001 Fill=0000
..\lib\cx16.lib(gt.o):
CODE Offs=018477 Size=00000A Align=00001 Fill=0000
..\lib\cx16.lib(icmp.o):
CODE Offs=018481 Size=00002E Align=00001 Fill=0000
..\lib\cx16.lib(incax2.o):
CODE Offs=0184AF Size=000007 Align=00001 Fill=0000
..\lib\cx16.lib(incax3.o):
CODE Offs=0184B6 Size=000005 Align=00001 Fill=0000
..\lib\cx16.lib(incax8.o):
CODE Offs=0184BB Size=000005 Align=00001 Fill=0000
..\lib\cx16.lib(incaxy.o):
CODE Offs=0184C0 Size=00000B Align=00001 Fill=0000
..\lib\cx16.lib(incsp1.o):
CODE Offs=0184CB Size=000007 Align=00001 Fill=0000
..\lib\cx16.lib(incsp2.o):
CODE Offs=0184D2 Size=000015 Align=00001 Fill=0000
..\lib\cx16.lib(incsp3.o):
CODE Offs=0184E7 Size=000005 Align=00001 Fill=0000
..\lib\cx16.lib(incsp4.o):
CODE Offs=0184EC Size=000005 Align=00001 Fill=0000
..\lib\cx16.lib(incsp6.o):
CODE Offs=0184F1 Size=000005 Align=00001 Fill=0000
..\lib\cx16.lib(incsp8.o):
CODE Offs=0184F6 Size=000005 Align=00001 Fill=0000
..\lib\cx16.lib(isspace.o):
CODE Offs=0184FB Size=000008 Align=00001 Fill=0000
..\lib\cx16.lib(isupper.o):
CODE Offs=018503 Size=000008 Align=00001 Fill=0000
..\lib\cx16.lib(jmpvec.o):
DATA Offs=0026C6 Size=000003 Align=00001 Fill=0000
..\lib\cx16.lib(kernal.o):
..\lib\cx16.lib(ladd.o):
CODE Offs=01850B Size=000024 Align=00001 Fill=0000
..\lib\cx16.lib(land.o):
CODE Offs=01852F Size=000021 Align=00001 Fill=0000
..\lib\cx16.lib(ldaui.o):
CODE Offs=018550 Size=000009 Align=00001 Fill=0000
..\lib\cx16.lib(ldaxi.o):
CODE Offs=018559 Size=00000D Align=00001 Fill=0000
..\lib\cx16.lib(ldaxsp.o):
CODE Offs=018566 Size=000009 Align=00001 Fill=0000
..\lib\cx16.lib(ldeaxi.o):
CODE Offs=01856F Size=000017 Align=00001 Fill=0000
..\lib\cx16.lib(le.o):
CODE Offs=018586 Size=00000A Align=00001 Fill=0000
..\lib\cx16.lib(leaaxsp.o):
CODE Offs=018590 Size=00000C Align=00001 Fill=0000
..\lib\cx16.lib(lmul.o):
CODE Offs=01859C Size=000059 Align=00001 Fill=0000
..\lib\cx16.lib(lneg.o):
CODE Offs=0185F5 Size=00001E Align=00001 Fill=0000
..\lib\cx16.lib(loadaddr.o):
LOADADDR Offs=000000 Size=000002 Align=00001 Fill=0000
..\lib\cx16.lib(lor.o):
CODE Offs=018613 Size=000021 Align=00001 Fill=0000
..\lib\cx16.lib(lpush.o):
CODE Offs=018634 Size=00001E Align=00001 Fill=0000
..\lib\cx16.lib(lsub.o):
CODE Offs=018652 Size=000024 Align=00001 Fill=0000
..\lib\cx16.lib(lt.o):
CODE Offs=018676 Size=00000A Align=00001 Fill=0000
..\lib\cx16.lib(ltoa.o):
CODE Offs=018680 Size=000093 Align=00001 Fill=0000
..\lib\cx16.lib(lxor.o):
CODE Offs=018713 Size=000021 Align=00001 Fill=0000
..\lib\cx16.lib(mainargs.o):
DATA Offs=0026C9 Size=000016 Align=00001 Fill=0000
ONCE Offs=000045 Size=00006A Align=00001 Fill=0000
INIT Offs=000003 Size=000012 Align=00001 Fill=0000
..\lib\cx16.lib(makebool.o):
CODE Offs=018734 Size=00002C Align=00001 Fill=0000
..\lib\cx16.lib(malloc.o):
CODE Offs=018760 Size=00010E Align=00001 Fill=0000 270 bytes
..\lib\cx16.lib(memcpy.o):
CODE Offs=01886E Size=00003C Align=00001 Fill=0000
..\lib\cx16.lib(memset.o):
CODE Offs=0188AA Size=00005D Align=00001 Fill=0000
..\lib\cx16.lib(mktime.o):
CODE Offs=018907 Size=0003D1 Align=00001 Fill=0000 977 bytes
RODATA Offs=00FD2C Size=00002E Align=00001 Fill=0000
..\lib\cx16.lib(mod.o):
CODE Offs=018CD8 Size=000011 Align=00001 Fill=0000
..\lib\cx16.lib(mul.o):
CODE Offs=018CE9 Size=000045 Align=00001 Fill=0000
..\lib\cx16.lib(mul8.o):
CODE Offs=018D2E Size=00003A Align=00001 Fill=0000
..\lib\cx16.lib(mulax10.o):
CODE Offs=018D68 Size=000019 Align=00001 Fill=0000
..\lib\cx16.lib(mulax3.o):
CODE Offs=018D81 Size=000011 Align=00001 Fill=0000
..\lib\cx16.lib(mulax5.o):
CODE Offs=018D92 Size=000014 Align=00001 Fill=0000
..\lib\cx16.lib(mulax6.o):
CODE Offs=018DA6 Size=000016 Align=00001 Fill=0000
..\lib\cx16.lib(ne.o):
CODE Offs=018DBC Size=00000A Align=00001 Fill=0000
..\lib\cx16.lib(negabs.o):
CODE Offs=018DC6 Size=000012 Align=00001 Fill=0000
..\lib\cx16.lib(open.o):
CODE Offs=018DD8 Size=0000BE Align=00001 Fill=0000
..\lib\cx16.lib(oserror.o):
CODE Offs=018E96 Size=000016 Align=00001 Fill=0000
RODATA Offs=00FD5A Size=00005A Align=00001 Fill=0000
..\lib\cx16.lib(popptr1.o):
CODE Offs=018EAC Size=00000E Align=00001 Fill=0000
..\lib\cx16.lib(push1.o):
CODE Offs=018EBA Size=000005 Align=00001 Fill=0000
..\lib\cx16.lib(pusha.o):
CODE Offs=018EBF Size=000016 Align=00001 Fill=0000
..\lib\cx16.lib(pushax.o):
CODE Offs=018ED5 Size=00001A Align=00001 Fill=0000
..\lib\cx16.lib(pushwsp.o):
CODE Offs=018EEF Size=00001C Align=00001 Fill=0000
..\lib\cx16.lib(putchar.o):
CODE Offs=018F0B Size=00000C Align=00001 Fill=0000
..\lib\cx16.lib(read.o):
CODE Offs=018F17 Size=00007C Align=00001 Fill=0000
BSS Offs=000A08 Size=000001 Align=00001 Fill=0000
ONCE Offs=0000AF Size=00000C Align=00001 Fill=0000
..\lib\cx16.lib(regswap2.o):
CODE Offs=018F93 Size=000016 Align=00001 Fill=0000
..\lib\cx16.lib(return0.o):
CODE Offs=018FA9 Size=000004 Align=00001 Fill=0000
..\lib\cx16.lib(rwcommon.o):
CODE Offs=018FAD Size=00001A Align=00001 Fill=0000
..\lib\cx16.lib(scratch.o):
CODE Offs=018FC7 Size=000019 Align=00001 Fill=0000
..\lib\cx16.lib(shelp.o):
CODE Offs=018FE0 Size=000020 Align=00001 Fill=0000
..\lib\cx16.lib(shrax1.o):
CODE Offs=019000 Size=000008 Align=00001 Fill=0000
..\lib\cx16.lib(shrax2.o):
CODE Offs=019008 Size=00000B Align=00001 Fill=0000
..\lib\cx16.lib(shrax3.o):
CODE Offs=019013 Size=00000E Align=00001 Fill=0000
..\lib\cx16.lib(shrax4.o):
CODE Offs=019021 Size=000011 Align=00001 Fill=0000
..\lib\cx16.lib(sprintf.o):
CODE Offs=019032 Size=00002B Align=00001 Fill=0000
BSS Offs=000A09 Size=000001 Align=00001 Fill=0000
..\lib\cx16.lib(staspidx.o):
CODE Offs=01905D Size=000016 Align=00001 Fill=0000
..\lib\cx16.lib(staxsp.o):
CODE Offs=019073 Size=00000B Align=00001 Fill=0000
..\lib\cx16.lib(staxspi.o):
CODE Offs=01907E Size=00001A Align=00001 Fill=0000
..\lib\cx16.lib(steaxspi.o):
CODE Offs=019098 Size=000022 Align=00001 Fill=0000
..\lib\cx16.lib(strcat.o):
CODE Offs=0190BA Size=00002F Align=00001 Fill=0000
..\lib\cx16.lib(strchr.o):
CODE Offs=0190E9 Size=000025 Align=00001 Fill=0000
..\lib\cx16.lib(strcmp.o):
CODE Offs=01910E Size=000021 Align=00001 Fill=0000
..\lib\cx16.lib(strcpy.o):
CODE Offs=01912F Size=00001F Align=00001 Fill=0000
..\lib\cx16.lib(strlen.o):
CODE Offs=01914E Size=000016 Align=00001 Fill=0000
..\lib\cx16.lib(strlower.o):
CODE Offs=019164 Size=000027 Align=00001 Fill=0000
..\lib\cx16.lib(sub.o):
CODE Offs=01918B Size=000014 Align=00001 Fill=0000
..\lib\cx16.lib(subeqsp.o):
CODE Offs=01919F Size=000015 Align=00001 Fill=0000
..\lib\cx16.lib(subysp.o):
CODE Offs=0191B4 Size=00000D Align=00001 Fill=0000
..\lib\cx16.lib(time.o):
CODE Offs=0191C1 Size=000043 Align=00001 Fill=0000
BSS Offs=000A0A Size=000008 Align=00001 Fill=0000
..\lib\cx16.lib(timezone.o):
DATA Offs=0026DF Size=00000F Align=00001 Fill=0000
..\lib\cx16.lib(tmcommon.o):
CODE Offs=019204 Size=00000D Align=00001 Fill=0000
DATA Offs=0026EE Size=000012 Align=00001 Fill=0000
..\lib\cx16.lib(tolower.o):
CODE Offs=019211 Size=000012 Align=00001 Fill=0000
..\lib\cx16.lib(toslong.o):
CODE Offs=019223 Size=000032 Align=00001 Fill=0000
..\lib\cx16.lib(udiv.o):
CODE Offs=019255 Size=00004F Align=00001 Fill=0000
..\lib\cx16.lib(ugt.o):
CODE Offs=0192A4 Size=00000A Align=00001 Fill=0000
..\lib\cx16.lib(ult.o):
CODE Offs=0192AE Size=000008 Align=00001 Fill=0000
..\lib\cx16.lib(umod.o):
CODE Offs=0192B6 Size=000011 Align=00001 Fill=0000
..\lib\cx16.lib(vsnprintf.o):
CODE Offs=0192C7 Size=0000DA Align=00001 Fill=0000
DATA Offs=002700 Size=000008 Align=00001 Fill=0000
..\lib\cx16.lib(vsprintf.o):
CODE Offs=0193A1 Size=000012 Align=00001 Fill=0000
..\lib\cx16.lib(write.o):
CODE Offs=0193B3 Size=000052 Align=00001 Fill=0000
ONCE Offs=0000BB Size=000011 Align=00001 Fill=0000
..\lib\cx16.lib(xor.o):
CODE Offs=019405 Size=000011 Align=00001 Fill=0000
..\lib\cx16.lib(zerobss.o):
CODE Offs=019416 Size=000023 Align=00001 Fill=0000
..\lib\cx16.lib(zeropage.o):
ZEROPAGE Offs=000000 Size=00001A Align=00001 Fill=0000
Segment list:
Name Start End Size Align
ZEROPAGE 000022 00003B 00001A 00001
LOADADDR 0007FF 000800 000002 00001
EXEHDR 000801 00080C 00000C 00001
STARTUP 00080D 00082D 000021 00001
CODE 00082E 019C66 019439 00001 103,481 bytes [game ~96K C-library ~7K]
BRAM01ADDR 009FFE 009FFF 000002 00001
BRAM02ADDR 009FFE 009FFF 000002 00001
BRAM03ADDR 009FFE 009FFF 000002 00001
BRAM04ADDR 009FFE 009FFF 000002 00001
BRAM05ADDR 009FFE 009FFF 000002 00001
BRAM06ADDR 009FFE 009FFF 000002 00001
BRAM07ADDR 009FFE 009FFF 000002 00001
BRAM08ADDR 009FFE 009FFF 000002 00001
BRAM09ADDR 009FFE 009FFF 000002 00001
RODATA 019C67 029A20 00FDBA 00001 64,954 bytes [game]
DATA 029A21 02C128 002708 00001 9,992 bytes [game]
INIT 02C129 02C13D 000015 00001
BSS 02C13E 02CB4F 000A12 00001
ONCE 02C13E 02C213 0000D6 00001
