Where can I download the Commander x16 manual?
dario144
Post by dario144 »
I recently downloaded the emulator but have no idea what the commands are. Is there a manual in pdf?
JimmyDansbo
Re: Where can I download the Commander x16 manual?
Post by JimmyDansbo »
Best place to find up to date information is:
https://github.com/X16Community/x16-docs
For a manual, have a look at:
https://github.com/X16Community/x16-user-guide
Other than that, the Commander X16 is compatible with Commodore 64 BASIC
https://www.c64-wiki.com/wiki/BASIC
Visit my Github repo
dario144
Post by dario144 »
thnx!!
dario144
Post by dario144 »
Commands like "screen n" which controls character size, is a X16 exclusive command. By luck, I stumbled onto it. It's not a C64 command. It is a list those types of x16 commands I am looking for.
JimmyDansbo wrote: Sun Sep 03, 2023 1:21 pm Best place to find up to date information is:
JimmyDansbo
Then you are most likely looking for this:
https://github.com/X16Community/x16-doc ... 20BASIC.md
dario144
Post by dario144 »
JimmyDansbo wrote: Sun Sep 03, 2023 4:15 pm Then you are most likely looking for this:
if I wanted to load a file in my HDD, what would I type?
dario144
Post by dario144 »
btw... the link is exactly what I need! thanks!
dario144 wrote: Sun Sep 03, 2023 3:13 pm Commands like "screen n" which controls character size, is a X16 exclusive command.
Well, yes and no. It does change the character size, but only to fit the configuration of the selected screen. You can't arbitrarily change sizes on the same screen.
JimmyDansbo
dario144 wrote: Sun Sep 03, 2023 6:21 pm if I wanted to load a file in my HDD, what would I type?
I usually go to the directory where the file I want to load is and start the emulator from there:
windows:
cd \path\to\my\game\or\program
c:\path\to\emulator\x16emu -prg the-program-i-want-to-run.prg
linux:
cd /path/to/my/game/or/program
/path/to/emulator/x16emu -prg the-program-i-want-to-run.prg
You can also start the emulator without the -prg option and then use:
DOS"$
or
LOAD"$"
LIST
In order for DOS and LOAD/LIST to be useful, your program usually have to be saved with only CAPITAL letters
If you're using the latest ROM version (R44), the directory listing will be case-converted... I'm not sure if that's universal or if it's only a feature on the emulator, and if it's the latter, if it's specific to which OS and/or filesystem you're using.
