Have you talked to the design team? None of them use the forums.
Expansion slots
Re: Expansion slots
IIRC, they aren't necessarily tri-state latches, so they may not be able to go into a high-impedance state.
If the glue logic involved a choice between /Resettable latches and tri-state latches, you can see why resettable latches would be a priority, since you want the ROM latch to come up in a known starting state on system reset.
And of course the points already made about they are not at the stage of the project where they are going to do any breaking changes just to chase specialized niche benefits ... they are at the stage of the project where they are only going to do a breaking change if there is a lurking hidden bug that will otherwise cause a serious headache.
Re: Expansion slots
For the reason noted, that it's a simpler circuit to select on one bit to select an entire power of two space, versus notching one 64KB segment out of a power of two space, and also that it's upwardly expandable, where if segment $FF is actually used to access the X16 main memory map, then $80-$FE are available for special modes.TomXP411 wrote: ↑Sun May 14, 2023 1:25 amSure, but why? The original Super CPU could handle 16MB of RAM. I wouldn't settle for less if I was trying to create a Super CPU X16 Edition.BruceRMcF wrote: ↑Sun May 14, 2023 12:23 am If 8MB memory space on the card suffices, you can have any segment of $80 and above access the X16 main memory map, then when you latch the segment address, bit0 to bit6 can connect directly to the card memory bus A16 to A22 and bit7 selects between the card address space and the X16 address space.
It's not like a direct 8MB 65816 RAM space limits the card to 8MB if there are DMA capabilities ... the limit on the DMA memory is the width set aside for the DMA RAM address, so the DMA memory could well work with a 32bit address space.
Re: Expansion slots
I don't think that's a good trade. 8MB for a slightly simpler chip select logic doesn't sit well with me.BruceRMcF wrote: ↑Tue May 16, 2023 11:31 pmFor the reason noted, that it's a simpler circuit to select on one bit to select an entire power of two space, versus notching one 64KB segment out of a power of two space, and also that it's upwardly expandable, where if segment $FF is actually used to access the X16 main memory map, then $80-$FE are available for special modesTomXP411 wrote: ↑Sun May 14, 2023 1:25 amSure, but why? The original Super CPU could handle 16MB of RAM. I wouldn't settle for less if I was trying to create a Super CPU X16 Edition.BruceRMcF wrote: ↑Sun May 14, 2023 12:23 am If 8MB memory space on the card suffices, you can have any segment of $80 and above access the X16 main memory map, then when you latch the segment address, bit0 to bit6 can connect directly to the card memory bus A16 to A22 and bit7 selects between the card address space and the X16 address space.
Re: Expansion slots
[/quote]
I assumed they were due to the need for vectors being duplicated on all roms, but realised this wouldn't cover the situation where the bank pointed to invalid memory, or the vector was invalid.
There is no octal latch with reset and output enable, only a quad which would double the chips needed. I guess somthing like an sr latch which would disable the bank latch on vector pull but re enable it on write would work, the original content can be restored from the shadow ram value.
Re: Expansion slots
While I am thinking 8MB might be overkill for where directly addressed memory dominates the arbitrarily large DMA memory, which is superior for writing data to video or sound chips.. At about $15 q1, a 16Mbit 45ns part might do me for SRAM, which only occupy a quarter of the directly addressable SRAM.TomXP411 wrote: ↑Wed May 17, 2023 12:57 amI don't think that's a good trade. 8MB for a slightly simpler chip select logic doesn't sit well with me.BruceRMcF wrote: ↑Tue May 16, 2023 11:31 pmFor the reason noted, that it's a simpler circuit to select on one bit to select an entire power of two space, versus notching one 64KB segment out of a power of two space, and also that it's upwardly expandable, where if segment $FF is actually used to access the X16 main memory map, then $80-$FE are available for special modes
Re: Expansion slots
Just so I'm clear from having followed this interesting & spirited discussion...
If I WRITE to the banked ROM space for banks above #0-#31 and I have an expansion card with RAM mapped in to the ROM space, the data that is written by the CPU will actually be stored in the RAM, assuming I've wired the RAM up correctly?
The application I'm thinking of here is. simple Expansion card with RAM occupying several ROM banks at #32 and above that will be useful for speedier development of ROM-based code for cartridges etc.
Something like the circuit below/attached
- Cartridge RAM in ROM Banks
- Slide1.png (234.69 KiB) Viewed 639660 times
Re: Expansion slots
This seems OK, I wouldn't put the activity led on the OE line as this is bad for rise fall times, better to buffer it with the extra gate. Not sure how you'd program it unless this is just a simplified schMartin Schmalenbach wrote: ↑Fri Jun 30, 2023 4:34 am Just so I'm clear from having followed this interesting & spirited discussion...
Re: Expansion slots
Oh wait I just saw an issue. You need to watch A15 A14 from the slot to see if you are accessing the rom address space. Not (A15 & A14) - > #CEMartin Schmalenbach wrote: ↑Fri Jun 30, 2023 4:34 am Just so I'm clear from having followed this interesting & spirited discussion...
Re: Expansion slots
Good catch on the activity LED - thanks!spargue wrote: ↑Sat Jul 01, 2023 10:20 pmThis seems OK, I wouldn't put the activity led on the OE line as this is bad for rise fall times, better to buffer it with the extra gate. Not sure how you'd program it unless this is just a simplified schMartin Schmalenbach wrote: ↑Fri Jun 30, 2023 4:34 am Just so I'm clear from having followed this interesting & spirited discussion...
