Just went about all my mostly finished projects and attached Tokenized BASIC files that can just be downloaded and then "LOADed"
Copy - Ctrl-V was the best on the emulator but now you can just download them copy to SD card and LOAD/RUN on Hardware.
CODEBLTZ
MYSTIFY
CRAPS VER 1.0
CRAPS VER 2.0
and the program to do the VERA Color chart all have attached TOKENIZED Basic files now.
POSTED TOKENIZED VERSIONS
Re: POSTED TOKENIZED VERSIONS
Also took the Liberty of doing this for one other person's code. One of the best
Demo's I saw for the FM commands under BASIC
