Switching to R43 frustration
ch4rl3sb
Post by ch4rl3sb »
Another thing I've been meaning to ask:
Does a line interrupt trigger at the beginning or end of the line in question? When the line starts or when it hits the horizontal blank?
Johan Kårlin
Post by Johan Kårlin »
StephenHorn wrote: Thu Jun 01, 2023 4:58 pm I dimly recall there being some PRs having to do with VERA IRQ triggering and line IRQs... ah, yeah, found the change that matters in the emulation code. In January this year (2023 for time travelers from the future), a change went in to match emulation behavior with hardware behavior. On VERA hardware, the ISR bits are set regardless of the state of the IEN bits -- IEN only controls whether VERA generates an interrupt request to the CPU when certain ISR bits are set.
Previous to that change, the relationship in the emulator was the other way around, and IEN bits would control whether ISR bits could ever get set, and VERA would generate interrupt requests if any bits in ISR were set. This means the line interrupt bit is pretty much guaranteed to be set most of the time -- it just doesn't generate interrupts anymore unless the appropriate IEN bit is set.
Thanks for making this clear! I have been confused by this too. I had code that stopped working and I didn’t understand why. I made some changes and got it working again without really knowing what I was doing. But now I get it. :)
ch4rl3sb
Post by ch4rl3sb »
Well, that does work! Thank you so much.
Now it just has some sprite position anomalies at the beginning of the game that weren't there before. Maybe to do with the randomized ram? (Your spaceship changes position then fires bullets that come out of a different position out of thin air for a few seconds, then everything settles into normal. But that's a new problem.)
StephenHorn
Post by StephenHorn »
ch4rl3sb wrote: Thu Jun 01, 2023 7:13 pm Another thing I've been meaning to ask:
The emulator is setting the bit in VERA ISR at the start of the visible line. That said, there are several possible places where a change to VERA state will take effect. I don't remember the exact list off the top of my head, but in general the background layer settings are applied 2 scanlines after they are set, I think VSTART is applied on the next line (please don't hold me to that), and other state changes are applied immediately (i.e. are visible mid-scanline and can benefit/suffer from "racing the beam" techniques).
Someone please correct me if I'm getting this wrong.
ch4rl3sb wrote: Thu Jun 01, 2023 7:44 pm Well, that does work! Thank you so much.
You can easily check if this is the case by running the emulator with the -zeroram command line option. That will clear the ram to zero again which was the old behavior, but it is not what the hardware is doing.
I have similar frustrations with the way files are handled now, particularly with subfolders. No matter what I do I can't seem to load a file if it's in a subfolder.
I wrote some code to save a file with the following filename:
@:DEMO/IMG/PIX40.DAT
And that saved PIX40.DAT properly in the IMG subfolder in the DEMO folder.
But no matter what filename I try I cannot load that file back into memory. Here's some of the filenames I tried:
DEMO/IMG/PIX40.DAT
/DEMO/IMG/PIX40.DAT
DEMO:/IMG:/PIX40.DAT
DEMO/IMG/:PIX40.DAT
DEMO/:IMG/:PIX40.DAT
DEMO/IMG:/PIX40.DAT
:/DEMO/IMG:/PIX40.DAT
and so on and so on.
So what am I missing? And why not simply leave it the way it was in r41, the way every other computer system that has used subfolders for the last 40 years? Why make it a unique syntax?
Ed Minchau wrote: Thu Jul 13, 2023 11:48 pm I have similar frustrations with the way files are handled now, particularly with subfolders. No matter what I do I can't seem to load a file if it's in a subfolder.
DEMO/IMG/PIX40.DAT
/DEMO/IMG/PIX40.DAT
DEMO/IMG/:PIX40.DAT
DEMO/IMG:/PIX40.DAT
This sounds like a bug. I'll ping MooingLemur on this and see if he has any insight.
update: I can save and load from subdirectories with the usual syntax:
Screenshot 2023-07-13 171543.png (10.81 KiB) Viewed 20947 times
Make sure you're using the -fsroot parameter when starting the emulator and point that to a directory with your files. I have a "root" directory parallel to my emu directory, like this:
C:\CX16\Emulator
C:\CX16\root
and I start the emu with .\emulator\x16emu.exe -scale 2 -echo -rtc -fsroot .\root
Ender
Post by Ender »
DEMO/IMG/PIX40.DAT
/DEMO/IMG/PIX40.DAT
DEMO/IMG/:PIX40.DAT
DEMO/IMG:/PIX40.DAT
What is the exact command you are using? The first format seems to work fine for me.
BLOAD "TETRADS/SOUNDS.BIN",8,1,$A000
SEARCHING FOR TETRADS/SOUNDS.BIN
LOADING FROM $01:A000 TO $05:B3EB
READY.
EDIT: Nevermind, Tom beat me to it :D
That's a file in a folder. I need a file in a subfolder in a folder.
I did a quick look at the kernal rom, and the parser wants something like this:
"@0/HERES/MY/PATH/:FILE.PRG"
I think you can omit the leading number (it's the "medium" and it defaults to zero). The path part must begin and end with a slash, and the part directly after the colon is the filename plus options like usual.
I can't test right now to confirm, sorry.
