How do I get sound?
ch4rl3sb
How do I get sound?
Post by ch4rl3sb »
I'm using R41 of the emulator and just started trying to do sound tests. But I can't get sound to work.
What do I need?
Re: How do I get sound?
The first thing I'm going suggest is upgrading to R43.
https://github.com/X16Community/x16-emu ... es/tag/r43
ch4rl3sb
Post by ch4rl3sb »
First, Jaw drop, I had heard of R42 and R43 but had not seen a link to them!
https://github.com/commanderx16/x16-emulator/releases this was the only link I had to emulators!
next, R43 seems to have broken everything else I had... i.e. joysticks, my game loads but I have no controls.
(-joy1 wasn't working in R41 either, it defaulted to keyboard, but -joy2 worked.)
ch4rl3sb
Post by ch4rl3sb »
You don't have to use the -sound option to get sound unless you want the sound output to go to a specific device. And then, you have to use the FULL description.
-sound "Speakers (Realtek(R) Audio)"
ch4rl3sb
Post by ch4rl3sb »
ah. "quotation marks" to surround the full title. didn't know that. cause Speakers (Real...etc.) didn't work.
but, I can't seem to get any sound in the first place. will try again.
Are you in Windows or Linux
ch4rl3sb
Post by ch4rl3sb »
Windows 10. couldn't get sound on R38, R41, or R43.
When you say you can't get sound.....
Game programs run but no sound ?
You tried the FMPLAY or PSGPLAY in BASIC ?
I assume that in the Host system (Windows 10 in your case) sound is working properly
