Petscii Editor
ScragglyHermit
Petscii Editor
Post by ScragglyHermit »
A very simple petscii graphic editor for the x-16. With only a few functions:
  • enter a single char
  • draw a line
  • draw a rectangle
  • copy a region
  • save a drawing
  • load a drawing
HELP.PSK - example file and also help
Binary File format  (.PSK):
  • a few bytes for the header (will change)
  • 2 bytes for width (currently only 80)
  • 2 bytes for height (currently only 60)
  • data array of interleaved character code (1 byte) and color (1 byte). Almost the same as Vera except Vera pads width to 256 columns (not 80).
Improved UI. Added menus and copy tool.
Petscii Editor
Petscii Editor
Petscii Editor
Petscii Editor
petscii_edit.prg
Petscii Editor
(25.47 KiB) Downloaded 331 times
[The extension psk has been deactivated and can no longer be displayed.]
