How To Read The Directory In BASIC (Updated)
Tutorials and help articles.
The following program reads the directory and prints it on the screen. This was intentionally NOT broken down into subroutines (GOSUB/RETURN), for simplicity's sake.
The CBM directory structure is broken down exactly like a BASIC program.
The first two bytes of the file are the load address and can be safely discarded (1010).
Lines 1100-1050 read the line link (the address of the next line in memory) and discard those, as well. The file size is a two-byte integer, which we have to read in low-high order. This is why the H*256+L in line 1140.
Then we can read the disk title. This is just PETSCII text, prefixed with the Reverse symbol. So I read up to the next quote symbol, turn off RVS, and finish out the line.
Line 1210 is my standard practice for getting a byte out of a file. The program not only needs to read from disk, but needs to check for zero bytes. Since a zero byte is read as an empty string (""), the program checks for this and assigns A the PETSCII value. This allows us to check for special characters later.  (Yes, this can be simplified for performance.)
BASIC lines end with a zero byte, so line 1220 finishes the line when we read a zero.
Finally, the main loop:
1300-1360 reads the link and file size, then prints them on the screen.
1400-1490 trims the leading spaces and prints the text of the filename and date.
1500-1550 is just a "raw read" routine that we don't need, but I left in as an example of reading hex data from the disk.
9000: don't forget to close your files, or you'll run out of channels pretty quickly. The only way to recover from that is a reset.
0 REM READ DIRECTORY IN BASIC
5 COLOR 1,6
10 OPEN 8,8,0,"$=T"
1000 REM READ 2 BYTES AND DISCARD
1010 GET#8,A$:GET#8,A$
1100 REM READ LINK AND FILE SIZE
1110 GET#8,A$:GET#8,A$
1120 L=0:GET#8,A$:IF A$<>"" THEN L=ASC(A$)
1130 H=0:GET#8,A$:IF A$<>"" THEN H=ASC(A$)
1140 FS=H*256+L
1150 PRINT FS;
1200 REM READ DISK TITLE
1210 GET#8,A$:A=0:IF A$<>""THEN A=ASC(A$)
1220 IF A=0 THEN PRINT: GOTO 1300
1230 PRINT A$;
1240 IF A=34 THEN PRINT "\X92";
1270 IF ST=0 THEN 1210
1300 REM READ LINK AND FILE SIZE
1310 GET#8,A$:GET#8,A$
1320 L=0:GET#8,A$:IF A$<>"" THEN L=ASC(A$)
1330 H=0:GET#8,A$:IF A$<>"" THEN H=ASC(A$)
1340 FS=H*256+L
1350 PRINT FS;
1360 IF ST<>0 THEN 9000
1400 REM READ FILENAME
1410 PRINT TAB(5);
1420 GET#8,A$:A=0:IF A$<>""THEN A=ASC(A$)
1430 IF A<>32 THEN 1460
1440 GOTO 1420
1450 GET#8,A$:A=0:IF A$<>""THEN A=ASC(A$)
1460 IF A=0 THEN PRINT : GOTO 1300
1470 PRINT A$;
1480 IF ST<>0 THEN 9000
1490 GOTO 1450
1500 REM DEBUG - READ RAW DATA
1510 GET#8,A$:A=0:IF A$<>""THEN A=ASC(A$)
1520 IF A>=32 AND A<128 THEN PRINT A$;:GOTO 1340
1530 PRINT "\XCD";HEX$(A);
1540 IF ST=0 THEN 1310
1550 RETURN
9000 CLOSE 8
9101 END
