r41 Release Candidates
Michael Steil
Post by Michael Steil »
On 5/7/2022 at 3:52 PM, Michael Steil said:
This is RC2:
http://www.pagetable.com/docs/tmp/x16emu_linux-r41_rc2.zip
http://www.pagetable.com/docs/tmp/x16emu_mac-r41_rc2.zip
http://www.pagetable.com/docs/tmp/x16emu_win-r41_rc2.zip
Difference: Default layout has no dead keys, can reach all of ISO-8859-15 using (Shift+)Alt/AltGr.
mobluse
Post by mobluse »
Doesn't work in EN-US United States (with Mac extensions):
Alt+;    =    ×
Alt+X    . (Alt+x followed by space gives .; Alt+x seems to be a dead key.)
Alt+,    ␣    ,
Alt+.    ␣    .
These should work according to https://github.com/commanderx16/x16-docs/blob/master/X16 Reference - 02 - Editor.md
The only real problem is how to type × (multiplication sign, $D7).
I found this helpful page: https://sites.psu.edu/symbolcodes/mac/codemacext/
In Linux a similar map is English (US) - English (Macintosh): setxkbmap us mac
That is not exactly the same U.S. Extended in macOS: https://askubuntu.com/questions/292729/keyboard-layout-identical-to-us-extended-on-macbook-pro
Michael Steil
Alt+;    =    ×
Alt+,    ␣    ,
Alt+.    ␣    .
Wow, thanks for testing it all. These were all documentation bugs, which are now fixed.
  • Alt+; = should be Shift+Alt+; =
  • Alt+. ␣ should be Alt+x ␣ (Yes, Alt+x is a dead key)
  • Alt+, ␣ should be Alt+p ␣
mobluse
Post by mobluse »
There are still some characters that cannot be typed in ISO mode AFAIK: ¬¹²³.
BTW this Mac keyboard layout is called U.S. Extended or ABC Extended; not just U.S. or ABC because that is a slightly different layout with some AltGr dead keys on other positions.
Michael Steil
You are right! Those as well as µ are not reachable. (My auto-test code was faulty.)
Michael Steil
I added µ to Alt+m and ¬ to Alt+l. This is consistent with the default US Mac layout and replaced dead/not useful keys.
mobluse
Post by mobluse »
Also SHY i.e. CHR$($AD) is not reachable. I didn't read all of this article, but one could type SHY (Syllable HYphen) at the end of a line to indicate that this hyphen can be removed, i.e. a sort of line-continuation character for words: https://jkorpela.fi/shy.html
NBSP i.e. CHR$($A0) is reachable.
Michael Steil
Agreed, macOS calls it "ABC - Extended". I changed its identifier to "ABC/X16", and the docs call it "ABC - Extended (X16)".
Michael Steil
This is RC3:
http://www.pagetable.com/docs/tmp/x16emu_linux-r41_rc3.zip
http://www.pagetable.com/docs/tmp/x16emu_mac-r41_rc3.zip
http://www.pagetable.com/docs/tmp/x16emu_win-r41_rc3.zip
All ISO chars are now reachable. As a bonus, Shift+Alt+k produces the X16 logo (in ISO mode).
If I didn't break anything, I'll release this as r41.
SlithyMatt
Post by SlithyMatt »
On 5/15/2022 at 2:32 AM, Michael Steil said:
This is RC3:
Can you make these HTTPS links so that they aren't so scary for browsers?
